    DIY Tablet
      anernest last edited by
      Re: Explore unlimited possibilities - Coolpi 8-inch touchscreen
      I would like to build a tablet using the Cm5 core board and v2 carrier board used in the CM5 laptop. I have the 14in CM5 laptop and am very pleased with its stablity as a daily-driver. Shrinking it down to an 8 or 10in tablet form-factor would be ideal. I've got the touchscreen and boards in my cart on Aliexpress and am ready to pull the trigger pending any feedback on the following potential concerns:
      1. Heat management (low profile heatsink/fan like the laptop?)
      2. Structural rigidity (PLA 3D print case?)
      3. Hardware buttons (power, volume, brightness, etc)
      4. 5G Cellular Modem possibilty
      Any insights/thoughts would be greatly appreciated.
      Andy
        george @anernest last edited by
        @anernest
        We are looking forward to your work and can provide technical support.
        Thank you!
        A 2 Replies Last reply Reply Quote 0
          anernest @george last edited by
          @george is it possible to connect all the following to the main simutaneously somehow?
          • NVMe SSD
          • Wifi
          • Quectel RM500Q-GL 5G modem
            @anernest
            These features are already supported on laptop products.
              @george how could you explain how I could connect the Quectel RM500Q-GL 5G modem? I finally got around to purchasing the components for my tablet build and just received them. The Wifi module already occupies the A/E key M.2 slot, and I'm hoping to add an SSD to the other SSD M.2 slot. Are there enough lanes available on the M.2 slot to split for an SSD and the 5G modem?
                @george Is there a 10 or 11in touchscreen that would work with the CM5 core board and V20 Carrier Board?
                  @anernest
                  Ensure that the LCD is an EDP interface and the touch is an IIC interface. In principle, it can light up normally, but the driver part needs to be modified. Check if there are any universal specifications later.
