    build openwrt souce code
    Openwrt
      jack_admin last edited by
      step1:
      git clone https://gitee.com/yanyitech/openwrt.git
      cd openwrt
      ### Quickstart
      1. Run `./scripts/feeds update -a` to obtain all the latest package definitions
         defined in feeds.conf / feeds.conf.default
      2. Run `./scripts/feeds install -a` to install symlinks for all obtained
         packages into package/feeds/
      3. Run `make menuconfig` to select your preferred configuration for the
         toolchain, target system & firmware packages.
      4. Run `make` to build your firmware. This will download all sources, build the
         cross-compile toolchain and then cross-compile the GNU/Linux kernel & all chosen
         applications for your target system.
      1 Reply Last reply Reply Quote -1
