    Do Face Detection on Coolpi with FastDeploy
      zhengbicheng last edited by zhengbicheng
      Brief Introduction
      With the improvement of AI computing power, Face Detection algorithms have gradually shifted from machine learning to deep learning. Through this tutorial, you will learn how to use FastDeploy to quickly implement face detection on Coolpi.
      What is SCRFD
      SCRFD is an efficient high accuracy face detection approach which initially described in Arxiv, and accepted by ICLR-2022. In order to facilitate you to quickly understand the parameters of the model, we only give the parameters of common models. If you need to view the detailed data of the model, please go to InsightFace's official Github.
      Name Easy Medium Hard FLOPs Params(M)
      SCRFD_500M_KPS 90.97 88.44 69.49 500M 0.57
      SCRFD_2.5G_KPS 93.80 92.02 77.13 2.5G 0.82
      SCRFD_10G_KPS 95.40 94.01 82.80 10G 4.23
      Workflow
      # Download CoolPI-AI
      git clone https://github.com/yanyitech/coolpi-ai.git
      # Go to face detection demo
      cd example/face_detection
      # Build and make
      mkdir build
      cd build
      cmake .. -DFASTDEPLOY_INSTALL_DIR=${PWD}/../../../third_party/fastdeploy-develop
      make -j8
      # Download model and picture
      wget https://bj.bcebos.com/paddlehub/fastdeploy/rknpu2/scrfd_500m_bnkps_shape640x640_rknpu2.zip
      unzip scrfd_500m_bnkps_shape640x640_rknpu2.zip
      wget https://raw.githubusercontent.com/DefTruth/lite.ai.toolkit/main/examples/lite/resources/test_lite_face_detector_3.jpg
      # Run
      ./infer_with_scrfd scrfd_500m_bnkps_shape640x640_rknpu2/scrfd_500m_bnkps_shape640x640_rk3588_quantized.rknn \
                    test_lite_face_detector_3.jpg \
      How to transform the model
      If you need to convert your ONNX model to RKNN model, FastDeploy also provides the corresponding method. You only need to modify the configuration file of the model in the tools/rknpu2/config to achieve rapid model conversion
      git clone https://github.com/PaddlePaddle/FastDeploy.git
      wget  https://bj.bcebos.com/paddlehub/fastdeploy/rknpu2/scrfd_500m_bnkps_shape640x640.zip
      unzip scrfd_500m_bnkps_shape640x640.zip
      python  /Path/To/FastDeploy/tools/rknpu2/export.py \
              --config_path tools/rknpu2/config/scrfd_quantized.yaml \
              --target_platform rk3588
      Result
      Input Data
      Output Data
      Navigation
      • Introduction to FastDeploy
      • Introduction to SCRFD
