    Coolpi PWM
      macthree last edited by
      任何人都可以解释如何在 coolpi 上使用 PWM 吗?
        大法师 @macthree last edited by 大法师
        @macthree 有部分GPIO支持硬件PWM功能,当然也可以用GPIO模拟PWM功能。
        https://www.cool-pi.com/topic/80/coolpi-4b硬件扩展五-pwm
          macthree @大法师 last edited by
          使用 raspberry pi wiring.h 需要包含访问 PWM,如下所示.
          coolpi 需要包括什么?
          C Program
          Change the Intensity of LED using PWM on Raspberry Pi
          http://www.electronicwings.com
          #include <wiringPi.h>
          #include <stdio.h>
          #include <stdlib.h>
          const int PWM_pin = 1; /* GPIO 1 as per WiringPi, GPIO18 as per BCM */
          int main (void)
          int intensity ;
          if (wiringPiSetup () == -1)
          exit (1) ;
          pinMode (PWM_pin, PWM_OUTPUT) ; /* set PWM pin as output */
          while (1)
          for (intensity = 0 ; intensity < 1024 ; ++intensity)
            pwmWrite (PWM_pin, intensity) ;	/* provide PWM value for duty cycle */
            delay (1) ;
          delay(1);
          for (intensity = 1023 ; intensity >= 0 ; --intensity)
            delay (1) ;
          delay(1);
            @macthree
            这是软PWM,需要重写封装WiringPi
            • Moved from Hardware by  大法师 大法师
