    是否有 pin22 & pin24 接 Dmic Example?
      tonyone0902 last edited by
      40 pin HAT 那邊 pin22 & pin24 分別有 PDM CLK & PDM Data,請問如果在 ubuntu 環境下如何透過這兩個腳位直接擷取 Dmic 音訊呢?
        • DTS is modified as follows
        diff --git a/arch/arm64/boot/dts/rockchip/rk3588s-cp4.dts b/arch/arm64/boot/dts/rockchip/rk3588s-cp4.dts
        index dc232a407a8c..da9796bfe7a3 100755
        --- a/arch/arm64/boot/dts/rockchip/rk3588s-cp4.dts
        +++ b/arch/arm64/boot/dts/rockchip/rk3588s-cp4.dts
        @@ -223,6 +223,24 @@ codec {
        +       pdmics: dummy-codec {
        +        status = "okay";
        +        compatible = "rockchip,dummy-codec";
        +        #sound-dai-cells = <0>;
        +    pdm_mic_array: pdm-mic-array {
        +        status = "okay";
        +        compatible = "simple-audio-card";
        +        simple-audio-card,name = "rockchip,pdm-mic-array";
        +        simple-audio-card,cpu {
        +            sound-dai = <&pdm1>;
        +        simple-audio-card,codec {
        +            sound-dai = <&pdmics>;
                leds: leds {
                        compatible = "gpio-leds";
                        pinctrl-names = "default";
        @@ -944,6 +962,14 @@ &route_hdmi0 {
                status = "okay";
        +&pdm1 {
        +    status = "okay";
        +    rockchip,path-map = <0 1 2 3>;
        +    pinctrl-names = "default";
        +    pinctrl-0 = <&pdm1m1_clk &pdm1m1_sdi1>;
         &i2c0 {
                status = "okay";
        @@ -1301,7 +1327,7 @@ ir_key1 {
         &spi0 {
        -       status = "okay";
        +       status = "disabled";
                max-freq = <48000000>; /* spi internal clk, don't modify */
                 spi_dev@0 {
        • Device information
        coolpi@Ubuntu:~$ arecord -l
        **** List of CAPTURE Hardware Devices ****
        card 2: rockchipes8316c [rockchip,es8316-codec], device 0: fe470000.i2s-ES8316 HiFi es8316.7-0010-0 [fe470000.i2s-ES8316 HiFi es8316.7-0010-0]
          Subdevices: 1/1
          Subdevice #0: subdevice #0
        card 3: rockchippdmmica [rockchip,pdm-mic-array], device 0: fe4c0000.pdm-dummy_codec dummy-codec-0 [fe4c0000.pdm-dummy_codec dummy-codec-0]
          Subdevices: 1/1
          tonyone0902 @george last edited by
          Thanks!
