    coolpi 4b无法启动
      test last edited by
      烧录百度网盘以下两个固件到sd卡,都无法启动
      日志如下:
      DDR Version V1.07 20220412
      LPDDR4X, 2112MHz
      channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
      channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
      channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
      channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
      change to F1: 528MHz
      change to F2: 1068MHz
      change to F3: 1560MHz
      change to F0: 2112MHz
      out
      INFO: Preloader serial: 2
      NOTICE: BL31: v2.3():v2.3-364-g55ca4fb1c:derrick.huang
      NOTICE: BL31: Built : 12:00:02, May 13 2022
      INFO: timer_hp_init no valid 32k timer source, use normal mode
      INFO: GICv3 without legacy support detected.
      INFO: ARM GICv3 driver initialized in EL3
      INFO: system boots from cpu-hwid-0
      INFO: idle_st=0x21fff, pd_st=0x11fff9
      INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
      INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
      INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
      INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
      INFO: BL31: Initialising Exception Handling Framework
      INFO: BL31: Initializing runtime services
      INFO: BL31: Initializing BL32
      INFO: hdmirx_handler: dma not on, ret
      I/TC:
      I/TC: OP-TEE version: 3.13.0-639-g8e053a881-dev #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Mon Mar 14 09:09:01 CST 2022 aarch64
      I/TC: Primary CPU switching to normal world boot
      INFO: BL31: Preparing for EL3 exit to normal world
      INFO: Entry point address = 0x200000
      INFO: SPSR = 0x3c9
      COOLPI LOADER BY YANYI(Nov 02 2022)
      DRAM: 3.7 GiB
      Using default environment
      0 2 1 3 6 8 7 9 trsv ln0 mon rx cdr lock timeout
      dp@fde50000 disconnected
      hdmi info isn't saved in main block
      mode:1920x1080 bus_format:0x100a
      hdmi@fde80000: detailed mode clock 148500 kHz, flags[5]
      H: 1920 2008 2052 2200
      V: 1080 1084 1089 1125
      bus_format: 100a
      VOP update mode to: 1920x1080p0, type: HDMI0 for VP0
      dclk:148500,if_pixclk_div;2,if_dclk_div:4
      rockchip_vop2_init: hdmi0_phy_pll may not define
      rockchip_vop2_init: hdmi1_phy_pll may not define
      assigned-clock-parents's node not define
      VP0 set crtc_clock to 148500KHz
      VOP VP0 enable Esmart0[356x124->356x124@782x478] fmt[1] addr[0xedf21000]
      CEA mode used vic=16
      mtmdsclock:148500000
      bus_width:0x16a8c8,bit_rate:1485000
      hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000
      hdptx phy pll locked!
      hdptx phy lane locked!
      dw_hdmi_setup HDMI mode
      don't use dsc mode
      dw hdmi qp use tmds mode
      Autoboot in 1 seconds
      Loading order: usb - tf - emmc
      resetting USB...
      scanning usb for storage devices... 0 Storage Device(s) found
      ** Bad device usb 0 **
      bank id invalid
      switch to partitions #0, OK
      mmc1 is current device
      ** Invalid partition 1 **
      Card did not respond to voltage select!
      mmc_init: -95, time 17
      ** Bad device mmc 0 **
      mmc_init: -95, time 16
      LPDDR4X, 2112MHz
      out
      I/TC:
      INFO: SPSR = 0x3c9
      DRAM: 3.7 GiB
      bus_format: 100a
      don't use dsc mode
      resetting USB...
      bank id invalid
      LPDDR4X, 2112MHz
      out
      I/TC:
      INFO: SPSR = 0x3c9
      DRAM: 3.7 GiB
      G J 2 Replies Last reply Reply Quote 0
        test last edited by
          test last edited by
          X 1 Reply Last reply Reply Quote 0
          • X
            xingzhan2012 @test last edited by
            @test 不装散热器?
              george @test last edited by
              @test 这是没有正确识别到TF卡的系统分区,TF卡先格式化一次,然后重新制作启动盘。
                jack_admin @test last edited by jack_admin
                @test 你的loader版本看起来比较早,升级loader试下。卡的分区表异常,格式化一次
