Cool-pi 4b case
Hi! Is there a case for the Cool-pi 4b or is there one which could fit it? The board size and components are similar to Raspberry Pi but I think the Mini Dp port doesn't allow to use an Rpi case.. Let me know!
@Mz3D-0
Yes, the mini dp port is a bit higher than the micro hdmi. We have also designed a heat sink that can be referenced.
@Mz3D-0 You can purchase the CP4B official radiator kit from the agent
@george Thanks! Could you provide a link where to buy it? On Aliexpress I can only find the 64Gb model with the radiator but I would like to buy the 128Gb with radiator
@george isn't the radiator version available with 128Gb emmc?
@Mz3D-0 https://www.aliexpress.com/item/1005005149770453.html?spm=a2g0o.productlist.main.53.4cbc61feCn9FnV&algo_pvid=47a3679c-7dc0-4002-add0-f49e311eb4cb&algo_exp_id=47a3679c-7dc0-4002-add0-f49e311eb4cb-26&pdp_npi=3%40dis!USD!237.67!237.67!!!!!%40211bda9b16811874036293419d076c!12000031868491517!sea!US!247094177&curPageLogUid=ADEuuAqgT9sr&gatewayAdapt=4itemAdapt
@jack_admin thanks!
