    Full Record of CM5 Running ChatGLM-MNN Big Language Model
      This example is based on the COOLPI CM5 32G memory version, and the system is ubuntu20.04.
      • Download ChatGLM-MNN project
      git clone https://github.com/wangzhaode/ChatGLM-MNN.git
      • Compile MNN library
      git clone https://github.com/alibaba/MNN.git
      cd MNN
      mkdir build && cd build
      cmake .. # CPU only
      make -j8
      cp -r ../include ../../ChatGLM-MNN/
      cp libMNN.so ../../ChatGLM-MNN/libs
      cp express/libMNN_Express.so ../../ChatGLM-MNN/libs
      • Download Models
      cd ChatGLM-MNN/resource/models
      ./download_models.sh int8
      cp int8/* ./
      • Build
      mkdir build
      cd build
      cmake ..
      make -j8
      • Run
      coolpi@Ubuntu:~/share/ChatGLM-MNN/build$ ./cli_demo
      The device support i8sdot:1, support fp16:1, support i8mm: 0
      Can't Find type=2 backend, use 3 instead
      load ../resource/tokenizer/slim_vocab.txt ... Done!
      load ../resource/models/glm_block_0.mnn model ... Done!
      load ../resource/models/glm_block_1.mnn model ... Done!
      load ../resource/models/glm_block_2.mnn model ... Done!
      load ../resource/models/glm_block_3.mnn model ... Done!
      load ../resource/models/glm_block_4.mnn model ... Done!
      load ../resource/models/glm_block_5.mnn model ... Done!
      load ../resource/models/glm_block_6.mnn model ... Done!
      load ../resource/models/glm_block_7.mnn model ... Done!
      load ../resource/models/glm_block_8.mnn model ... Done!
      load ../resource/models/glm_block_9.mnn model ... Done!
      load ../resource/models/glm_block_10.mnn model ... Done!
      load ../resource/models/glm_block_11.mnn model ... Done!
      load ../resource/models/glm_block_12.mnn model ... Done!
      load ../resource/models/glm_block_13.mnn model ... Done!
      load ../resource/models/glm_block_14.mnn model ... Done!
      load ../resource/models/glm_block_15.mnn model ... Done!
      load ../resource/models/glm_block_16.mnn model ... Done!
      load ../resource/models/glm_block_17.mnn model ... Done!
      load ../resource/models/glm_block_18.mnn model ... Done!
      load ../resource/models/glm_block_19.mnn model ... Done!
      load ../resource/models/glm_block_20.mnn model ... Done!
      load ../resource/models/glm_block_21.mnn model ... Done!
      load ../resource/models/glm_block_22.mnn model ... Done!
      load ../resource/models/glm_block_23.mnn model ... Done!
      load ../resource/models/glm_block_24.mnn model ... Done!
      load ../resource/models/glm_block_25.mnn model ... Done!
      load ../resource/models/glm_block_26.mnn model ... Done!
      load ../resource/models/glm_block_27.mnn model ... Done!
      load ../resource/models/lm.mnn model ... Done!
      Q: 写一首描绘冬天的诗
      A:  漫天雪花飞舞,
      寒风呼啸,大地一片沉寂。
      冬天的气息弥漫,
      银装素裹的世界令人陶醉。
      树枝上挂满晶莹剔透的冰霜,
      寒风把它们吹得摇曳生姿。
      湖面上结满了厚厚的冰,
      划着小船的人们欢笑着前行。
      冬天是一个美丽而神秘的季节,
      让人感受到宁静和祥和。
      虽然它带来了一些不便,
      比如冷的天气和冰雪的覆盖,
      但它也是一年中最美好的时光。<eop>
      Q:
      顾 2 Replies Last reply Reply Quote 0
        顾真牛 @george last edited by
        @george 目前 MNN 量化不彻底,推理时实际还是f16,所以速度还是慢。
        而且 不是很稳定,应该说很不稳定,几条就会奔溃杀死进程。
          @george 作者是阿里达摩院的MNN框架组的王召德,我有他钉钉,我在天天催更
            george @顾真牛 last edited by
            @顾真牛 他如果需要环境调试,我们可以提供。
