    How to install OpenCL/Kronos/OpenGL on CM5-EVB
      tmb68 last edited by
      Can anyone provide the steps required to install OpenCL/Kronos/OpenGL on the CM5-EVB?
      Looking for support for the Mali-G610, not seeing UserSpace files on ARM or Rockchip sites.
      Thanks,
      TMB
        george @tmb68 last edited by
        @tmb68 said in How to install OpenCL/Kronos/OpenGL on CM5-EVB:
        Thanks,
        TMB
        The released Ubuntu system image is already integrated with G610 driver by default
          I was able to get the OpenGL glmark working with libgles2-mesa, and -dev, and mesa-utils install, but I am still stuck on OpenCL.
          When I try to compile and run a test OpenCL, I am getting :
          ClGetPlatformIDs (-1001)
          no platforms found.
          For example, for the RockPi4:
          https://wiki.radxa.com/Rockpi4/dev/install-opencl
          There is a mali-midgard package which installs the OpenCL backend for the Mali.
          So, I would expect there are packages available for generic ARM, NEON, MALI-G610 somewhere. Once installed, I should be able to see all of those as platforms to run OpenCL against.
          Thanks,
          TMB
          G 1 Reply Last reply Reply Quote -1
            @tmb68 The following figure shows the test results of OpenCl, and the testing method will be provided later.
            coolpi@Ubuntu:~/share/clpeak/build$ ./clpeak
            Platform: ARM Platform
            arm_release_ver of this libmali is 'g6p0-01eac0', rk_so_ver is '7'.
              Device: Mali-LODX r0p0
                Driver version  : 2.1 (Linux ARM64)
                Compute units   : 4
                Clock frequency : 1000 MHz
                Global memory bandwidth (GBPS)
                  float   : 21.35
                  float2  : 23.18
                  float4  : 24.05
                  float8  : 12.08
                  float16 : 11.06
                Single-precision compute (GFLOPS)
                  float   : 447.12
                  float2  : 476.20
                  float4  : 472.35
                  float8  : 440.72
                  float16 : 416.19
                Half-precision compute (GFLOPS)
                  half   : 447.25
                  half2  : 888.31
                  half4  : 921.77
                  half8  : 897.50
                  half16 : 856.49
                No double precision support! Skipped
                Integer compute (GIOPS)
                  int   : 126.55
                  int2  : 127.18
                  int4  : 126.64
                  int8  : 125.27
                  int16 : 125.79
                Integer compute Fast 24bit (GIOPS)
                  int   : 126.64
                  int2  : 127.23
                  int4  : 126.79
                  int8  : 125.30
                  int16 : 125.76
                Transfer bandwidth (GBPS)
                  enqueueWriteBuffer              : 7.31
                  enqueueReadBuffer               : 8.25
                  enqueueWriteBuffer non-blocking : 7.30
                  enqueueReadBuffer non-blocking  : 8.26
                  enqueueMapBuffer(for read)      : 61.83
                    memcpy from mapped ptr        : 9.57
                  enqueueUnmap(after write)       : 61.21
                    memcpy to mapped ptr          : 9.40
                Kernel launch latency : 19.97 us
              @tmb68 The OpenCL library file has been updated. Run the following command to update it:
              sudo apt-get update
              sudo apt-get upgrade
