    How to add swap file with cool pi 4b
      大法师 last edited by
      Swap is a space on a disk that is used when the amount of physical RAM memory is full. When a Linux system runs out of RAM, inactive pages are moved from the RAM to the swap space.
      Swap space can take the form of either a dedicated swap partition or a swap file. In most cases, when running Linux on a virtual machine, a swap partition is not present, so the only option is to create a swap file.
      Example Add 8GB swap memory
      sudo dd if=/dev/zero of=/swapfile bs=1M count=8096
      sudo chmod 0600 /swapfile
      sudo mkswap /swapfile
      sudo swapon /swapfile
      echo '/swapfile none swap sw 0 0' | sudo tee -a /etc/fstab
      sudo mount -a or reboot
      ubuntu@ubuntu:~$ free -h
                    total        used        free      shared  buff/cache   available
      Mem:          3.8Gi       3.2Gi       133Mi       110Mi       458Mi       443Mi
      Swap:         7.9Gi       1.0Mi       7.9Gi
      ubuntu@ubuntu:~$
      How to adjust the swappiness value
      refer info
