    CAN bus testing tools and commands
      Test tools
      Canutils is a commonly used CAN communication testing toolkit that includes five independent programs: canconfig, candump, canecho, cansend, and cansequence. The functions of these programs are briefly described as follows:
      • canconfig
        The parameters used to configure the CAN bus interface mainly include baud rate and mode.
      • candump
        Receive data from the CAN bus interface and print it in hexadecimal format to standard output, or output it to a specified file.
      • canecho
        Resend all data received from the CAN bus interface to the CAN bus interface.
      • cansend
        Send the specified data to the specified CAN bus interface.
      • cansequence
        Automatically repeat the increment number to the specified CAN bus interface, or specify the receive mode and verify the received increment number.
      • ip
        Configuration of CAN baud rate, functions, etc.
      Common commands
      • Query current network devices:
      ifconfig -a
      • CAN start:
      ip link set can0 down  //Close CAN
      ip link set can0 type can bitrate 500000 //Set bit rate of 500KHz:
      ip -details -statistics link show can0 //Print can0 information:
      ip -details -statistics link show can0 //Start CAN:
      • CAN sending:
      Send (standard frame, data frame, ID: 123, date: DEADBEEF):
      cansend can0 123#DEADBEEF
      Sending (standard frame, remote frame, ID: 123):
      cansend can0 123#R
      Send (extended frame, data frame, ID: 0000123, date: DEADBEEF):
      cansend can0 00000123#12345678
      Sending (extended frame, remote frame, ID: 0000123):
      cansend can0 00000123#R
      • CAN reception:
      Start printing and wait for reception:
      candump can0
