    cool pi boards run waydroid
      ubuntu22 (wayland) now have some errors.
      add args 'systemd.unified_cgroup_hierarchy=0'
      coolpi@coolpi:~$ cat /proc/cmdline
      root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 quiet systemd.unified_cgroup_hierarchy=0 splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:32:fa:e2:50:53:e8
      coolpi@coolpi:~$
      install waydroid:
      sudo apt install curl ca-certificates -y
      curl https://repo.waydro.id | sudo bash
      sudo apt install waydroid -y
      coolpi@coolpi:~$ sudo waydroid container start;waydroid session start
      coolpi@coolpi:~$ waydroid status
      Session:	RUNNING
      Container:	RUNNING
      Vendor type:	MAINLINE
      IP address:	UNKNOWN
      Session user:	coolpi(1000)
      Wayland display:	wayland-0
      coolpi@coolpi:~$
      coolpi@coolpi:~$
      coolpi@coolpi:~$ waydroid show-full-ui
      [14:55:56] Failed to get service waydroidplatform, trying again...
      [14:55:57] Failed to get service waydroidplatform, trying again...
      [14:55:58] Failed to get service waydroidplatform, trying again...
      ^CTraceback (most recent call last):
        File "/usr/bin/waydroid", line 9, in <module>
          sys.exit(tools.main())
        File "/usr/lib/waydroid/tools/__init__.py", line 126, in main
          actions.app_manager.showFullUI(args)
        File "/usr/lib/waydroid/tools/actions/app_manager.py", line 132, in showFullUI
          maybeLaunchLater(args, justShow)
        File "/usr/lib/waydroid/tools/actions/app_manager.py", line 69, in maybeLaunchLater
          launchNow()
        File "/usr/lib/waydroid/tools/actions/app_manager.py", line 120, in justShow
          platformService = IPlatform.get_service(args)
        File "/usr/lib/waydroid/tools/interfaces/IPlatform.py", line 318, in get_service
          time.sleep(1)
      KeyboardInterrupt
      coolpi@coolpi:~$ sudo waydroid shell
      [sudo] password for coolpi:
      :/ # uname  -a
      Linux waydroid 5.10.110 #13 SMP Thu Jun 15 10:17:49 CST 2023 aarch64
      06-16 07:00:50.694    50    50 E tombstoned: Tombstone written to: /data/tombstones/tombstone_28
      06-16 07:00:50.793  3013  3013 I ServiceManager: Waiting for service 'SurfaceFlinger' on '/dev/binder'...
      06-16 07:00:54.000  3013  3013 I chatty  : uid=1000 system_server identical 43 lines
      06-16 07:00:54.100  3013  3013 I ServiceManager: Waiting for service 'SurfaceFlinger' on '/dev/binder'...
      06-16 07:00:54.201  3013  3013 W ServiceManager: Service SurfaceFlinger didn't start. Returning NULL
      06-16 07:00:54.451  3013  3013 I ServiceManager: Waiting for service 'SurfaceFlinger' on '/dev/binder'...
      06-16 07:00:55.654  3013  3013 I ServiceManager: Waiting for service 'SurfaceFlinger' on '/dev/binder'...
      06-16 07:00:55.662  3079  3079 I SurfaceFlinger: Using HWComposer service: 'default'
      06-16 07:00:55.662  3079  3079 I SurfaceFlinger: SurfaceFlinger is starting
      06-16 07:00:55.663  3079  3079 I SurfaceFlinger: Disabling backpressure propagation
      06-16 07:00:55.663  3079  3079 I SurfaceFlinger: Disabling blur effects, they are not supported.
      06-16 07:00:55.663  3079  3079 I SurfaceFlinger: Treble testing override: 'false'
      06-16 07:00:55.664  3079  3079 I SurfaceFlinger: SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
      06-16 07:00:55.664  3079  3079 D RenderEngine: RenderEngine GLES Backend
      06-16 07:00:55.667  3079  3079 D libEGL  : loaded /vendor/lib64/egl/libEGL_mesa.so
      06-16 07:00:55.667  3079  3079 D libEGL  : loaded /vendor/lib64/egl/libGLESv1_CM_mesa.so
      06-16 07:00:55.668  3079  3079 D libEGL  : loaded /vendor/lib64/egl/libGLESv2_mesa.so
      06-16 07:00:55.671  3079  3079 W EGL-MAIN: MESA-LOADER: failed to open rknpu: dlopen failed: library "/vendor/lib64/dri/rknpu_dri.so" not found (search paths /vendor/lib64/dri, suffix _dri)
      06-16 07:00:55.671  3079  3079 W EGL-MAIN: Failed to open any DRM device
      06-16 07:00:55.672  3079  3079 W EGL-MAIN: Failed to open any DRM device
      06-16 07:00:55.672  3079  3079 W libEGL  : eglInitialize(0xb400007f9ec41000) failed (EGL_NOT_INITIALIZED)
      06-16 07:00:55.672  3079  3079 E libEGL  : call to OpenGL ES API with no current context (logged once per thread)
      06-16 07:00:55.672  3079  3079 F RenderEngine: eglQueryStringImplementationANDROID(EGL_VERSION) failed
      06-16 07:00:55.672    50    50 I tombstoned: received crash request for pid 3079
      06-16 07:00:55.674  3079  3079 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
      06-16 07:00:55.674  3079  3079 F DEBUG   : LineageOS Version: '18.1-20230421-VANILLA-waydroid_arm64'
      06-16 07:00:55.674  3079  3079 F DEBUG   : Build fingerprint: 'waydroid/lineage_waydroid_arm64/waydroid_arm64:11/RQ3A.211001.001/32:userdebug/test-keys'
      06-16 07:00:55.674  3079  3079 F DEBUG   : Revision: '0'
      06-16 07:00:55.674  3079  3079 F DEBUG   : ABI: 'arm64'
      06-16 07:00:55.674  3079  3079 F DEBUG   : Timestamp: 2023-06-16 07:00:55+0000
      06-16 07:00:55.674  3079  3079 F DEBUG   : pid: 3079, tid: 3079, name: surfaceflinger  >>> /system/bin/surfaceflinger <<<
      06-16 07:00:55.674  3079  3079 F DEBUG   : uid: 1000
      06-16 07:00:55.674  3079  3079 F DEBUG   : signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
      06-16 07:00:55.674  3079  3079 F DEBUG   : Abort message: 'eglQueryStringImplementationANDROID(EGL_VERSION) failed'
      06-16 07:00:55.674  3079  3079 F DEBUG   :     x0  0000000000000000  x1  0000000000000c07  x2  0000000000000006  x3  0000007fcb454310
      06-16 07:00:55.674  3079  3079 F DEBUG   :     x4  00000000002e79ec  x5  00000000002e79ec  x6  00000000002e79ec  x7  0000007fa26c1000
      06-16 07:00:55.674  3079  3079 F DEBUG   :     x8  00000000000000f0  x9  c079f550d367498a  x10 0000000000000000  x11 ffffffc0ffffffdf
      06-16 07:00:55.674  3079  3079 F DEBUG   :     x12 0000000000000001  x13 0000000000000038  x14 0000000000000000  x15 ffffffffffffffff
      06-16 07:00:55.674  3079  3079 F DEBUG   :     x16 0000007fa0ad0948  x17 0000007fa0aaf410  x18 0000007fa1aa2000  x19 0000000000000c07
      06-16 07:00:55.674  3079  3079 F DEBUG   :     x20 0000000000000c07  x21 00000000ffffffff  x22 0000000300000001  x23 0000000000000001
      06-16 07:00:55.674  3079  3079 F DEBUG   :     x24 0000000000000003  x25 0000000000000000  x26 0000000000000000  x27 0000000000000000
      06-16 07:00:55.674  3079  3079 F DEBUG   :     x28 0000000000000000  x29 0000007fcb454390
      06-16 07:00:55.674  3079  3079 F DEBUG   :     lr  0000007fa0a61a9c  sp  0000007fcb4542f0  pc  0000007fa0a61ac8  pst 0000000000001000
      06-16 07:00:55.684  3079  3079 F DEBUG   :
      06-16 07:00:55.684  3079  3079 F DEBUG   : backtrace:
      06-16 07:00:55.684  3079  3079 F DEBUG   :       #00 pc 0000000000089ac8  /apex/com.android.runtime/lib64/bionic/libc.so (abort+164) (BuildId: e4cdaa3667d6b3fb35d46671d31909c3)
      06-16 07:00:55.684  3079  3079 F DEBUG   :       #01 pc 00000000000062b0  /system/lib64/liblog.so (__android_log_default_aborter+12) (BuildId: b5b2ed9d2859e7c956635d8bdb685c6f)
      06-16 07:00:55.684  3079  3079 F DEBUG   :       #02 pc 0000000000006e18  /system/lib64/liblog.so (__android_log_assert+336) (BuildId: b5b2ed9d2859e7c956635d8bdb685c6f)
      06-16 07:00:55.684  3079  3079 F DEBUG   :       #03 pc 000000000018db58  /system/lib64/libsurfaceflinger.so (android::renderengine::gl::GLESRenderEngine::create(android::renderengine::RenderEngineCreationArgs const&)+4320) (BuildId: 85d0b58d7dd2d26b021c8b09ffbd4753)
      06-16 07:00:55.684  3079  3079 F DEBUG   :       #04 pc 000000000018c928  /system/lib64/libsurfaceflinger.so (android::renderengine::RenderEngine::create(android::renderengine::RenderEngineCreationArgs const&)+168) (BuildId: 85d0b58d7dd2d26b021c8b09ffbd4753)
      06-16 07:00:55.684  3079  3079 F DEBUG   :       #05 pc 000000000010c868  /system/lib64/libsurfaceflinger.so (android::SurfaceFlinger::init()+184) (BuildId: 85d0b58d7dd2d26b021c8b09ffbd4753)
      06-16 07:00:55.684  3079  3079 F DEBUG   :       #06 pc 00000000000021b8  /system/bin/surfaceflinger (main+368) (BuildId: 2a5c373dbea113a5035b20ca4aed30fe)
      06-16 07:00:55.684  3079  3079 F DEBUG   :       #07 pc 000000000008506c  /apex/com.android.runtime/lib64/bionic/libc.so (__libc_init+108) (BuildId: e4cdaa3667d6b3fb35d46671d31909c3)
