    cool pi nano rv1106 with ubuntu22 server
      Booting system from tf card
      COOLPI LOADER BY YANYI(Jul 11 2023)
      DRAM:  256 MiB
      Using default environment
      boot mode: None
      eth0: ethernet@ffa80000
      Autoboot in 1 seconds
      switch to partitions #0, OK
      mmc1 is current device
      Scanning mmc 1:1...
      Found /extlinux/extlinux.conf
      192 bytes read in 6 ms (31.3 KiB/s)
      1:      Linux coolpi
      Retrieving file: /initrd32.img
      reading /initrd32.img
      35643864 bytes read in 2980 ms (11.4 MiB/s)
      Retrieving file: /vmlinuz
      reading /vmlinuz
      2173048 bytes read in 185 ms (11.2 MiB/s)
      append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 net.ifnames=0 rtleth=ethaddr:be:50:64:cc:c8:53
      Retrieving file: /rv1106-cpnano.dtb
      reading /rv1106-cpnano.dtb
      32649 bytes read in 7 ms (4.4 MiB/s)
      ## Flattened Device Tree blob at 0x00c00000
         Booting using the fdt blob at 0x00c00000
         Using Device Tree in place at 00c00000, end 00c0af88
      Adding bank: 0x00000000 - 0x10000000 (size: 0x10000000)
      Starting kernel ...
      ubuntu login: root
      Welcome to Ubuntu 22.04.2 LTS (GNU/Linux 5.10.110 armv7l)
       * Documentation:  https://help.ubuntu.com
       * Management:     https://landscape.canonical.com
       * Support:        https://ubuntu.com/advantage
        System information as of Fri Sep  9 18:51:14 UTC 2022
        System load:  0.353515625       Swap usage:  0%       Users logged in: 0
        Usage of /:   33.9% of 3.49GB   Temperature: 44.6 C
        Memory usage: 23%               Processes:   54
      Expanded Security Maintenance for Applications is not enabled.
      0 updates can be applied immediately.
      Enable ESM Apps to receive additional future security updates.
      See https://ubuntu.com/esm or run: sudo pro status
      The programs included with the Ubuntu system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
      applicable law.
      root@ubuntu:~# cat /proc/cpuinfo
      processor       : 0
      model name      : ARMv7 Processor rev 5 (v7l)
      BogoMIPS        : 69.82
      Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae
      CPU implementer : 0x41
      CPU architecture: 7
      CPU variant     : 0x0
      CPU part        : 0xc07
      CPU revision    : 5
      Hardware        : Generic DT based system
      Revision        : 0000
      Serial          : d3bd77b45eddde16
      root@ubuntu:~#
      • 3
        3395438 last edited by
        cool pi nano rv1106 啥时候推出来?
          大法师 @3395438 last edited by
          @3395438 资料整理中。同时近期会推出cool pi 笔记本产品
          3 1 Reply Last reply Reply Quote 0
          • 3
            3395438 @大法师 last edited by
            @大法师 加油,RV1106小巧,又有NPU,可玩性很高
              @3395438 👍 确实是好芯片
                这个啥时候出啊 都这么久了 要到明年?
