    A greate tool for creating disk image
      Genimage - The Image Creation Tool
      genimage is a tool to generate multiple filesystem and flash/disk images from a given root filesystem tree. genimage is intended to be run in a fakeroot environment.
      It also supports creating flash/disk images out of different file-system images and files.
      Configuration is done in a config file parsed by libconfuse. Options like the path to tools can be given via environment variables, the config file or from commandline switches.
      https://github.com/pengutronix/genimage
