    Cool Pi ARM Notebook Preview
    News
    13
    37
    14511
      Based on the CM5 core board
      Development Board Purchase Channel
      大法师 1 Reply Last reply Reply Quote 1
        大法师 @大法师 last edited by 大法师
        Appearance
        Product Style ID laptop
        Dimension(length * width *thickness) 323.4219.919.9 (H)mm
        net weight 1460g
        colour Space Grey+Black Key Core
        Surface Treatment Fuel injection、Silk screenprinting
        Shell material plastic
        Standard colors Shell Space Grey,Key capblack,Touchpad PET chip space gray
        CPU Type ARM 8cores (4 * A76+4 * A55)A76:2.2GHz A55:1.8GHz
        GPU Type ARM 4cores G610 1GHz
        LCD Screen size/resolution 14.1inch,1920*1080
        Screen ratio/surface technology/brightness 16:9 / 250cd/m2
        Screen structure size(length * width * thickness mm) 320.4187.13.0
        Storage RAM LPDDR4x 4/8/16/32GB
        ROM Emmc+SSD (optional)
        Extended Storage /
        WIFI frequency and protocol WiFi6 802.11ax
        Bluetooth Bluetooth version BT5.2
        Battery Capacity 38Wh (7.6V/5000MA)
        Camera Front 200W
        LED Power Y
        Charge Y
        Capitalization Y
        Number lock Y
        GPS Built-in GPS N
        FM FM N
        Sensor G_sensor N
        Light Sensor N
        Proxy-sensor N
        Hall Y
        Compass N
        Gyro Sensor N
        ATV Resolution/Support Country N
        DTV Standard/Support Country N
        Speaker Quantity/Power 8R/1W *2PCS
        Receiver Power N
        MIC built-in/daul mic Y,Analog MIC*1
        Vibration built-in N
        OTG built-in Y(Typec port support)
        HDMI Version and output resolution Y(HDMI2.1)8K
        Ethernet RJ45 N
        Fingerprint built-in N
        keyboard backlight/process N、Character screen printing American Englishkeyboard
        3G/4G model N
        Built in 3G upload/download speed
        Built in 3G frequency band
        Endurance Sleep standby time 130H
        Local video playback time 7H
        WIFI video playback time 7H
        Black screen charging time 3.5H
        Interface
        Button Physical button keyboard
        TF card Expand external storage N
        USB data transmission USB-A 3.0*1
        Headphone audio output 4-segment Φ 3.5mm standardheadphone interface * 1
        DC power input Y*1 ∮4.0mm
        HDMI High definition audio and videooutput Y1 TYPE-A HDMI1 2.1
        type-C Video and data transmission Y*1 USB3.0+DP1.4
        M.2 4G/3G/SSD Y*1Pcs,2280 PCIE only
        software
        OS Ubuntu/debian/uos/kylin/android Default Ubuntu 22.04
        Other specialrequirements
        Packaging accessories
        accessories 12V/2A plug-in DC tuningfork head with an outer diameter of 4.0mm and an inner diameter of 1.7mm and a head length of 10mm adapter, DC cable length of1.8 meters, with PSE, CE, UL, FCC, and 3C certifications.
        configuration Multiple language manuals,certificate of conformity, quality certificate, warranty card.
        Optional
          george @大法师 last edited by george
          @大法师 补充一张内部图片,支持全国产化定制。
          统信专业版,QQ 微信 WPS 邮件 CAD等软件流畅运行,办公追剧毫无压力。
          J N 顾 3 Replies Last reply Reply Quote 1
          • Pinned by  大法师 大法师
            能不能定制外壳啊 CM5的板子
              @jugg 详细需求?
                @george minipc
                  @jugg 四面出接口,定制外壳成本比较高。可以改底板双面出接口,这样可以用型材直接做,成本比较低。
                    @george 有没有现成的样机 买来看看
                      @jugg 暂时没有。
                        jack_admin @george last edited by 大法师
                        Coming soon, available for ordering
                        S 1 Reply Last reply Reply Quote 1
                          TheSwede86 last edited by
                          Hello,
                          Wondering if there are any plans to buy this with customized (language specific) keyboard layout?
                          Especially thinking about a "Nordic" keyboard layout (since I'm from Sweden and would be covered by this but it would also support other Nordic lanugages);
                          https://goblintechkeys.com/blogs/news/what-is-the-difference-between-nordic-layout-and-english-layout-keyboard
                          Best Regards
                            george @TheSwede86 last edited by
                            @TheSwede86 There is a minimum quantity requirement for keyboard customization, and how many quantities do you need. Thank you for your attention.
                            • S
                              S199pWa1k9r @jack_admin last edited by
                              Hi @jack_admin
                              The plastic back panel is a significant drawback. How much better would the cooling be if it were made of metal like the PineBook Pro from Pine64.
                                george @S199pWa1k9r last edited by
                                @S199pWa1k9r
                                Thank you for your suggestion. The main reason for choosing this shell is due to structural limitations. As our machine is designed with a core board and bottom board, the overall height will be higher than that of the single board method. At present, the metal shells on the market cannot meet the structural requirements.
                                We have conducted an evaluation on the heat dissipation, and the current heat dissipation method is to add graphene to the copper skin on the back. The temperature rise during normal video playback can be controlled to around 30 degrees Celsius.
                                • N
                                  ngavarta @george last edited by
                                  @george the air ventilation design doesn’t look logical to me, why is it doesn’t directly pulling hot air from the chip? No special cooling conductor to direct the heat from the main chip?
                                  N 1 Reply Last reply Reply Quote 0
                                  • N
                                    ngavarta @ngavarta last edited by
                                    @ngavarta said in Cool Pi ARM Notebook Preview:
                                    Well, although I can see why there are some benefit from this design, which is the accessibility to the CM5 module for swapping, but the may be we can consider a removable heat conductor or standalone heatsink and or fan doesn’t hurt 😋 …
                                      george @ngavarta last edited by
                                      @ngavarta
                                      In the early stage, there was a plan to use a copper tube heat sink as shown in the figure below for heat dissipation between the CM5 and the fan. Later, the machines shipped were changed to passive graphite copper sheet heat dissipation.
                                      Copper tube radiator:
                                      Graphene+copper sheet radiator:
                                      Temperature test data:
                                        顾子韵_w @george last edited by
                                        @george 请问核心板兼容香橙派的核心板吗?可以只买外设不要核心板吗?
                                          george @顾子韵_w last edited by george
                                          @顾子韵_w
                                          这款用的是COOLPI CM5的核心板,不兼容第三方的。
                                          • impressionyang
                                            impressionyang last edited by
                                            看起来还有很多空间可以摆放电池,有没有考虑过使用异形电池包来扩大电池容量呢?
                                            looooove cooooooding
                                              grognatou last edited by
                                              Hey !
                                              How can i buy it ? alibaba is not a good webstore for only one client. Can you make an aliexpress shop to sell it ? Thank you !
                                                george @grognatou last edited by
                                                @grognatou
                                                https://www.aliexpress.com/item/1005006690709030.html?spm=a2g0o.productlist.main.3.7efa3ca08JM0rg&algo_pvid=40a6025a-efeb-44cb-a9e4-c5e36a9cddb5&algo_exp_id=40a6025a-efeb-44cb-a9e4-c5e36a9cddb5-1&pdp_npi=4%40dis!USD!393.21!393.21!!!2835.00!2835.00!%40212bc77117114619924186626e5f65!12000038026438159!sea!US!2610428169!AB&curPageLogUid=d7xV5Y7wbK3D&utparam-url=scene%3Asearch|query_from%3A&gatewayAdapt=4itemAdapt
                                                  Momo 0 last edited by
                                                  Are there any plans for a Board revision that would allow charging through the USB-C port?
                                                    george @Momo 0 last edited by
                                                    @Momo-0
                                                    Currently, V2.0 machines can support TYPCE PD charging. You need to use an adapter that supports the PD protocol.
                                                      Momo 0 @george last edited by
                                                      @George is there a Possibility to buy the bare v2 board if we already have the Laptop?
                                                        george @Momo 0 last edited by george
                                                        @Momo-0 said in Cool Pi ARM Notebook Preview:
                                                        V2 bare boards can be purchased separately. You can communicate with customer service through the following link.
                                                        https://www.aliexpress.com/item/1005006690709030.html?gatewayAdapt=4itemAdapt
                                                        The bottom plate of V2 has been modified in four main ways:
                                                        1. As shown in the figure below, replace the WIFI module with a PCIE-M2 connector, which defaults to the RTL8852BE module and can be replaced by the user. Standard PCIE+USB interface.
                                                        2. The USB3.0 interface adds a redriver circuit to improve the compatibility of USB3.0.
                                                        3. Modify and add TYPEC PD charging support. Currently, it only supports PD charging when turned on, and does not currently support charging when turned off.
                                                        4. The LCD connector adds touch signals, allowing the machine to expand the touch screen.
                                                          @george and these boards fit the case of the older model perfectly?
                                                          M G 2 Replies Last reply Reply Quote 0
                                                            Momo 0 @Momo 0 last edited by
                                                            And is there a chance to ship to Germany?
                                                              @Momo-0
                                                              The structure is the same and can be directly replaced, then upgrade to the latest V20 software.
                                                              • K
        kaicn13 last edited by
        可不可以适配hp这些笔记本的磨具?替换原有的主板,
