    Ubuntu22.04挂载扩容Cool-PI-4B(eMMC 32GB)
    • H
      harry.huang last edited by 大法师
      Ubuntu22.04 默认更新系统后,只有8GB空间,以下进行扩容,使用100%空间
      • 更新前的容量如下:
      ubuntu@coolpi:~$ df -h
      Filesystem      Size  Used Avail Use% Mounted on
      tmpfs           372M  4.0M  368M   2% /run
      /dev/mmcblk0p2  6.4G  5.4G  704M  89% /
      tmpfs           1.9G     0  1.9G   0% /dev/shm
      tmpfs           5.0M  4.0K  5.0M   1% /run/lock
      tmpfs           372M  124K  372M   1% /run/user/1000
      ubuntu@coolpi:~$ sudo fdisk -l
      [sudo] password for ubuntu:
      Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
      Units: sectors of 1 * 512 = 512 bytes
      Sector size (logical/physical): 512 bytes / 4096 bytes
      I/O size (minimum/optimal): 4096 bytes / 4096 bytes
      Disk /dev/mmcblk0: 29.12 GiB, 31268536320 bytes, 61071360 sectors
      Sector size (logical/physical): 512 bytes / 512 bytes
      I/O size (minimum/optimal): 512 bytes / 512 bytes
      Disklabel type: dos
      Disk identifier: 0x6380c172
      Device         Boot  Start      End  Sectors  Size Id Type
      /dev/mmcblk0p1        2048   616447   614400  300M  b W95 FAT32
      /dev/mmcblk0p2      616448 14335999 13719552  6.5G 83 Linux
      • 采用parted命令进行扩容
      ubuntu@coolpi:~$ sudo parted /dev/mmcblk0
      GNU Parted 3.4
      Using /dev/mmcblk0
      Welcome to GNU Parted! Type 'help' to view a list of commands.
      • 输入resizepart进行重新分配空间,并退出
      (parted) resizepart
      Partition number? 2
      Warning: Partition /dev/mmcblk0p2 is being used. Are you sure you want to continue?
      Yes/No? YES
      End?  [7340MB]? 100%
      (parted) quit
      • 重启系统
      ubuntu@coolpi:~$ sudo reboot
      • 查看更新后的容量
      tmpfs           372M  3.9M  368M   2% /run
      /dev/mmcblk0p2   29G  5.4G   22G  20% /
      tmpfs           372M   88K  372M   1% /run/user/126
      tmpfs           372M   88K  372M   1% /run/user/1000
      Disklabel type: dos
      Disk identifier: 0x6da91944
      /dev/mmcblk0p2      616448 61071359 60454912 28.8G 83 Linux
      1 Reply Last reply Reply Quote 2
      • Referenced by  大法师 大法师
