    基于coolpi 4b进行Vue开发
      大法师 last edited by jack_admin
      什么是Vue
      Vue是一个开源的javascript框架,Vue.js 的目标是通过尽可能简单的API实现响应的数据绑定和组合的视图组件,Vue.js库的体积非常小的,并且不依赖其他基础库。
      Vue官网
      nodejs环境依赖安装 https://nodejs.org/en/download
      安装参考
      Using Ubuntu
      curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash - && sudo apt-get install -y nodejs
      Using Debian, as root
      curl -fsSL https://deb.nodesource.com/setup_20.x | bash - && apt-get install -y nodejs
      安装完成,检查node版本
      coolpi@coolpi:~/Desktop$ sudo apt-get install -y nodejs
      Reading package lists... Done
      Building dependency tree... Done
      Reading state information... Done
      The following packages were automatically installed and are no longer required:
        libjs-highlight.js libnode72
      Use 'sudo apt autoremove' to remove them.
      The following packages will be REMOVED:
        nodejs-doc
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 1 to remove and 20 not upgraded.
      1 not fully installed or removed.
      Need to get 29.4 MB/29.5 MB of archives.
      After this operation, 183 MB of additional disk space will be used.
      Get:1 https://deb.nodesource.com/node_20.x jammy/main arm64 nodejs arm64 20.5.1-deb-1nodesource1 [29.4 MB]
      Fetched 29.4 MB in 25s (1163 kB/s)
      debconf: delaying package configuration, since apt-utils is not installed
      (Reading database ... 144589 files and directories currently installed.)
      Removing nodejs-doc (12.22.9~dfsg-1ubuntu3) ...
      (Reading database ... 144410 files and directories currently installed.)
      Preparing to unpack .../nodejs_20.5.1-deb-1nodesource1_arm64.deb ...
      Unpacking nodejs (20.5.1-deb-1nodesource1) over (12.22.9~dfsg-1ubuntu3) ...
      Setting up nodejs (20.5.1-deb-1nodesource1) ...
      Processing triggers for man-db (2.10.2-1) ...
      coolpi@coolpi:~/Desktop$ node -v
      v20.5.1
      创建一个 Vue 应用
      coolpi@coolpi:~/Desktop$ mkdir project
      coolpi@coolpi:~/Desktop$ cd project/
      coolpi@coolpi:~/Desktop/project$ npm create vue@latest
      Need to install the following packages:
        create-vue@3.7.3
      Ok to proceed? (y) y
      Vue.js - The Progressive JavaScript Framework
      ✔ Project name: … vue-project
      ✔ Add TypeScript? … No / Yes
      ✔ Add JSX Support? … No / Yes
      ✔ Add Vue Router for Single Page Application development? … No / Yes
      ✔ Add Pinia for state management? … No / Yes
      ✔ Add Vitest for Unit Testing? … No / Yes
      ✔ Add an End-to-End Testing Solution? › No
      ✔ Add ESLint for code quality? … No / Yes
      Scaffolding project in /home/coolpi/Desktop/project/vue-project...
      Done. Now run:
        cd vue-project
        npm install
        npm run dev
      npm notice
      npm notice New major version of npm available! 9.8.0 -> 10.0.0
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.0.0
      npm notice Run npm install -g npm@10.0.0 to update!
      npm notice
      coolpi@coolpi:~/Desktop/project$ ls
      vue-project
      coolpi@coolpi:~/Desktop/project$ cd vue-project/
      coolpi@coolpi:~/Desktop/project/vue-project$ ls
      README.md  index.html  package.json  public  src  vite.config.js
      coolpi@coolpi:~/Desktop/project/vue-project$ npm install
      added 25 packages, and audited 26 packages in 15s
      3 packages are looking for funding
        run `npm fund` for details
      found 0 vulnerabilities
      coolpi@coolpi:~/Desktop/project/vue-project$ npm run dev
      > vue-project@0.0.0 dev
      > vite
        VITE v4.4.9  ready in 378 ms
        ➜  Local:   http://localhost:5173/
        ➜  Network: use --host to expose
        ➜  press h to show help
