    If there is a touch monitor that is compatible with coolpi cm5, please recommend it.
      etrin last edited by
      I connected the 7-inch Touch Protable Monitor Wisecoco product to coolpi cm5, but the screen keeps turning on/off, only the coolpi logo appears and blinks, and booting with the installed Ubuntu does not proceed. If there is a touch monitor that is compatible with coolpi, please recommend it. Reply please.
        大法师 @etrin last edited by
        @etrin Please confirm the typec power adapter. Also, did the ubuntu system burn successfully ?
        E 2 Replies Last reply Reply Quote 0
          etrin @大法师 last edited by
          @大法师 WisecocoTouchmonitor operates using a separate power source as the power provided by CoolFi's Type C is insufficient. Thanks for your answer.
            @大法师 How many amps of power should coolpi cm5 use?Is the Kulfi cm5 USB power output weak? How much is the USB output?
              @etrin Suggest using a 12V/2A power adapter. USB port current up to 1A.
                @大法师Thanks for your reply. Have a great weekend
