    Solved CoolPi 4B: Change output pins of i2c3 and i2c5
      maxpol last edited by
      According to the documentation, I can activate i2c3 and i2c5 with output pins 31, 33, 35, 37. Is it possible to change the output pins to other pins? Thank you.
        george @maxpol last edited by
        @maxpol
        Refer to the following documents:
        https://www.cool-pi.com/topic/70/coolpi-4b硬件扩展三-i2c?_=1695004097775
          @maxpol I2C3 I2C5 cannot be changed to other pinsOf course, you can try opening other I2C channels.
          M 1 Reply Last reply Reply Quote 1
            maxpol @george last edited by
            @george Thx a lot for your prompt response.
            Could you point me to the documents where I can figure out which i2c channels I might be able to open on the gpio pins?
              @maxpol
              • Topic has been marked as solved  M maxpol
