    I failed to install NoMachine on Coolpi cm5
      etrin last edited by
      I failed to install NoMachine on Coolpi cm5. I need some advice.
      (https://www.nomachine.com/)
      Or, by default, Ubuntu has RDP, but the password changes every time. Is there a way to prevent the access password from changing?
      I would like to ask for your advice.
      Thank you for reading the article.
      have a good day.
        大法师 @etrin last edited by
        @etrin
        Please confirm that the user login select Xorg desktop, not Wayland.
        coolpi@coolpi:~$ sudo dpkg -i nomachine_8.2.3_3_arm64.deb
        Selecting previously unselected package nomachine.
        (Reading database ... 326818 files and directories currently installed.)
        Preparing to unpack nomachine_8.2.3_3_arm64.deb ...
        Unpacking nomachine (8.2.3-3) ...
        Setting up nomachine (8.2.3-3) ...
        NX> 700 Starting installation at: Sat, 16 Sep 2023 15:49:54.
        NX> 700 Using installation profile: Ubuntu.
        NX> 700 Installation log is: /usr/NX/var/log/nxinstall.log.
        NX> 700 Installing nxrunner version: 8.2.3.
        NX> 700 Installing nxplayer version: 8.2.3.
        NX> 700 Installing nxnode version: 8.2.3.
        NX> 700 Installing nxserver version: 8.2.3.
        NX> 700 Installation completed at: Sat, 16 Sep 2023 15:50:26.
        NX> 700 NoMachine was configured to run the following services:
        NX> 700 NX service on port: 4000
        coolpi@coolpi:~$
          etrin @大法师 last edited by
          @大法师 Thank you for your reply. I will check with the information you provided.have a good day
