    Laptop install Ubuntu on nvme
    1689
      Momo 0 last edited by
      i have got the CM5 laptop that came with Ubuntu but i cant seem to install it on an nvme drive? Also when the laptop page mentioned uefi boot what does that mean exactly, can i install generic uefi arm-linux versions?
        Additionally does the cm5 not support sleep?
          george @Momo 0 last edited by
          @Momo-0
          The current images are written to EMMC by default. If you want to boot from nvme, you can perform partition copying on the system. Then modify the partition label on NVME, and then modify the label of the corresponding cmdline boot partition. You can achieve NVME charging and startup.
            @Momo-0
            Closing the laptop cover will put the machine into sleep mode.
            M 2 Replies Last reply Reply Quote 1
              Momo 0 @george last edited by
              @george thanks for the answers, it seems suspend isn’t working on my machine, as in it doesn’t wake up again.
              Also what are the future prospects for the Cool Pi architecture? Will it stay on these custom images or are there plans to get it to boot more general distributions?
                @Momo-0
                Currently, there is no open cover wake-up, and you need to manually press the power button. This is a known issue that can be resolved by updating the kernel in the future.
                As a development laptop, this machine will mainly focus on user-defined images. We have scripts for customized images available on Github, and we welcome everyone to download and use them.
                  @george i can confirm that with the latest ubuntu image the laptop will not wake even after pushing the power button
                    @Momo-0
                    After the laptop enters suspend mode, the power indicator light will turn off. When the power button is pressed again, the power indicator light of the machine will first light up, and then the machine will wake up.
                      @george when i close the lid the light stays on and the screen turns off. after that it doesn’t respond to the power button, so i have to forcefully shut it down by keeping the button pressed
                        @Momo-0
                        Is firmware stored in EMMC or NVME?
                          Momo 0 @george last edited by Momo 0
                          @george currently i have the home folders on an nvme, the rest is on the emmc
                          Also sometimes it wont boot and be stuck at a blinking underscore, from reeding it seems that both my issues could be videodriver issues
                          Edit: So the boot issue was a problem with my disk setup, and i did fix it, but i still can't get the laptop to suspend.
                            Momo 0 @Momo 0 last edited by Momo 0
                            @george So with the suspend issue, any idea? It would be really useful for the laptop to be able to suspend. Otherwise i currently have to set it to turn off on closing the Lid.
                              @Momo-0
                              Configure according to the factory's configuration (both the file system and kernel are placed in EMMC, while nvme only serves as a data disk). Is there a problem with suspend?
                                @george i tried both armbian and Ubuntu images flashed to emmc only and have the problem, if i suspend from menu and closing the lid. The power light stays on and the Laptop doesn't respond to keys. anything else i should try?
                                  @Momo-0
                                  After booting up, print a dmesg message and send it out. I think this should be a single machine issue. Normally, our machine does not have this problem.
                                    @george dmesg.txt
                                      @Momo-0
                                      There is no abnormal log information found in the dmesg information. Do you have any USB to serial port tools in your hand, and do you have some hands-on skills, such as welding and debugging serial ports. If further debugging information needs to be obtained, it is necessary to capture the logs of the serial port sleep wake up section to confirm the direction of the problem.
                                        For anyone who has a similar issue like me, it turned out the nvme ssd i was using didn't agree with the notebook when it came to sleep states. I swapped it with an WD Blue SN570 and now everything works as expected.
                                        G plumlis 2 Replies Last reply Reply Quote 1
                                          @Momo-0
                                          Thank you for sharing. If you have any questions during use, I hope you can raise them. Thank you very much for your support.
                                            plumlis @Momo 0 last edited by
                                            @Momo-0 Hi Which brand SSD are you using which effected this suspend sleeping issue?
                                            I know SN570 works fine but this quite hard to get one now. There is only SN580 on sale.
                                              Momo 0 @plumlis last edited by
                                              @plumlis it was an oem model I took from a damaged laptop, I also had issues with other oem nvmes I scavenged and used them in external enclosures on macOS, so I suspect ssds delivered to Laptop manufacturers have some kinda special firmwares, both times a new ssd worked without issues. my guess is any WD ssd can buy as a consumer will work.
                                              plumlis 1 Reply Last reply Reply Quote 0
                                                @Momo-0 Thank for your reply.
                                                I think the point is pcie 3.0 /4.0
                                                maybe pcie 3.0 version nvme ssd should be okay.
