    CoolPi 4b Ubuntu gst拉取usb摄像头不稳定,经常断开
      edwardzhou last edited by
      uname -a
      Linux Ubuntu 5.10.110 #5 SMP Thu Mar 2 17:39:26 CST 2023 aarch64 aarch64 aarch64 GNU/Linux
      系统是论坛上下载的Ubuntu
      cat /etc/lsb-release
      DISTRIB_ID=Ubuntu
      DISTRIB_RELEASE=22.04
      DISTRIB_CODENAME=jammy
      DISTRIB_DESCRIPTION="Ubuntu 22.04.3 LTS"
      USB摄像头:
      (rknn_py39) edwardzhou@Ubuntu:~/opencv_work/build$ v4l2-ctl -d /dev/video20 --all
      Driver Info:
      	Driver name      : uvcvideo
      	Card type        : USB PHY 2.0: USB CAMERA
      	Bus info         : usb-fc800000.usb-1.3
      	Driver version   : 5.10.110
      	Capabilities     : 0x84a00001
      		Video Capture
      		Metadata Capture
      		Streaming
      		Extended Pix Format
      		Device Capabilities
      	Device Caps      : 0x04200001
      		Video Capture
      		Streaming
      		Extended Pix Format
      Media Driver Info:
      	Model            : USB PHY 2.0: USB CAMERA
      	Serial           :
      	Media version    : 5.10.110
      	Hardware revision: 0x00000100 (256)
      Interface Info:
      	Type             : V4L Video
      Entity Info:
      	Name             : USB PHY 2.0: USB CAMERA
      	Function         : V4L2 I/O
      	Flags            : default
      	Pad 0x01000007   : 0: Sink
      	  Link 0x02000013: from remote pad 0x100000a of entity 'Extension 4' (Video Pixel Formatter): Data, Enabled, Immutable
      Priority: 2
      Video input : 0 (Camera 1: ok)
      Format Video Capture:
      	Width/Height      : 640/480
      	Pixel Format      : 'MJPG' (Motion-JPEG)
      	Field             : None
      	Bytes per Line    : 0
      	Size Image        : 4177920
      	Colorspace        : sRGB
      	Transfer Function : Rec. 709
      	YCbCr/HSV Encoding: ITU-R 601
      	Quantization      : Default (maps to Full Range)
      	Flags             :
      Crop Capability Video Capture:
      	Bounds      : Left 0, Top 0, Width 640, Height 480
      	Default     : Left 0, Top 0, Width 640, Height 480
      	Pixel Aspect: 1/1
      Selection Video Capture: crop_default, Left 0, Top 0, Width 640, Height 480, Flags:
      Selection Video Capture: crop_bounds, Left 0, Top 0, Width 640, Height 480, Flags:
      Streaming Parameters Video Capture:
      	Capabilities     : timeperframe
      	Frames per second: 30.000 (30/1)
      	Read buffers     : 0
            white_balance_temperature 0x0098091a (int)    : min=0 max=255 step=1 default=128 value=128
      发现有两个问题:
      1. usb摄像头如果接 USB3.0的那两个蓝色接口,无法工作,gst打不开。接 USB2.0的插口,才能工作。
      2. 用gst-launch-1.0 测试
        1) 有时会直接失败, 再次又能成功
        失败日志:
      (rknn_py39) edwardzhou@Ubuntu:~/opencv_work/build$ gst-launch-1.0 v4l2src device=/dev/video20 ! image/jpeg,width=640,height=480 ! jpegparse !  mppjpegdec ! videoconvert ! appsink
      Setting pipeline to PAUSED ...
      Pipeline is live and does not need PREROLL ...
      Pipeline is PREROLLED ...
      Setting pipeline to PLAYING ...
      New clock: GstSystemClock
      libv4l2: error turning on stream: Input/output error
      ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
      Additional debug info:
      ../sys/v4l2/gstv4l2src.c(800): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
      Buffer pool activation failed
      ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
      ../libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
      streaming stopped, reason not-negotiated (-4)
      Execution ended after 0:00:00.067890509
      Setting pipeline to NULL ...
      Freeing pipeline ...
      2) 能成功拉取,过十几秒又会自动中断
      开始成功的输出
      Redistribute latency...
      0:00:07.9 / 99:99:99.
      拉取过十几秒后失败 自动断开
      streaming stopped, reason error (-5)
      Execution ended after 0:00:13.670819439
        george @edwardzhou last edited by
        @edwardzhou dmesg传上来看一下有没有底层的报错信息。
          edwardzhou @george last edited by
          dmsg.log
            @edwardzhou
            从log信息看USB设备还是有兼容性问题,识别的时候有报错,如果手上有USB hub可以串接hub再测试。或者换一个USB摄像头模组确认一下问题。
