    Ubuntu22 install pip3
      ubuntu@coolpi:~$ sudo apt install python3-pip
      Reading package lists... Done
      Building dependency tree... Done
      Reading state information... Done
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
      The following packages have unmet dependencies:
       python3-distutils : Depends: python3:any (>= 3.10.5-0~)
                           Depends: python3-lib2to3 (= 3.10.6-1~22.04) but 3.10.4-0ubuntu1 is to be installed
      E: Unable to correct problems, you have held broken packages.
      ubuntu@coolpi:~$
      maybe the system hold some packages. Please take a try use command:
      apt-mask unhold python3* python3-* libpython3*
      • C
        ccjjww1222 last edited by
        sudo apt-mark unhold python3* python3-* libpython3*
        sudo apt-get install python3-pip
