    rk3588 vs i5-1135g7
      Run Management
      • Rockchip ARMv8 Cortex-A76 testing on Ubuntu 22.04 via the Phoronix Test Suite.
      • Results
      • HPL Linpack
        HPL is a well known portable Linpack implementation for distributed memory systems. This test profile is testing HPL upstream directly, outside the scope of the HPC Challenge test profile also available through the Phoronix Test Suite (hpcc). The test profile attempts to generate an optimized HPL.dat input file based on the CPU/memory under test. The automated HPL.dat input generation is still being tuned and thus for now this test profile remains "experimental".
      • 7-Zip Compression
        This is a test of 7-Zip compression/decompression with its integrated benchmark feature.
      • asmFish
        This is a test of asmFish, an advanced chess benchmark written in Assembly.
      • Timed Linux Kernel Compilation
      • Smallpt
        Smallpt is a C++ global illumination renderer written in less than 100 lines of code. Global illumination is done via unbiased Monte Carlo path tracing and there is multi-threading support via the OpenMP library.
      • m-queens
        A solver for the N-queens problem with multi-threading support via the OpenMP library.
      • N-Queens
        This is a test of the OpenMP version of a test that solves the N-queens problem. The board problem size is 18.
      • Aircrack-ng
        Aircrack-ng is a tool for assessing WiFi/WLAN network security.
      • SQLite Speedtest
        This is a benchmark of SQLite's speedtest1 benchmark program with an increased problem size of 1,000.
