    如何进入coolpi cm5-laptop的bios设置?
    1990
      reallaowu last edited by
      我购买了一台32G内存的coolpi CM5-laptop,发现预装的是32位的ubuntu,我从ubuntu官网下载了64 arm的桌面版本,并制作好了启动安装的u盘。但我不知道如何进入coolpi cm5-laptop的bios设置,将其设置为u盘启动。
      我的问题是:
      如何进入coolpi cm5-laptop的bios设置,更改启动选项
        george @reallaowu last edited by george
        @reallaowu
        coolpi的笔记本电脑和X86的方式不同的,coolpi是通过uboot引导的,镜像也不能使用ubuntu官方发布的,请按照如下文档操作更新:
        https://cool-pi.com/topic/514/cool-pi-cm5-laptop-linux-quick-start-guide
        R R 2 Replies Last reply Reply Quote 0
          reallaowu @george last edited by
          @george 谢谢,大概看了下文档,应该可以搞定。多谢:)
            Rock @reallaowu last edited by
            @reallaowu Could you please share your step by step procedures after you successfully installed Ubuntu 24.04 LTS via USB stick?
              Rock @george last edited by
              @george Could it be possible to offer a detailed step-by-step user manual for installing a Linux system through a USB stick without the need to connect to additional x86 computers or laptops?
                george @Rock last edited by
                @Rock
                1.First, download the image to the COOLPI laptop
                2.Then insert the USB drive into the laptop, double-click on the image and the following interface will pop up. 3.Then select the USB drive, and the image will be created into the USB drive
                4.Restart the laptop and the machine will boot from the USB drive. After entering the system, copy the 24.04 image into the USB drive.
                5.Double click on the 24.04 image in the USB drive directory, select EMMC (starting with AT29), and enter the root password. The image will be flushed into EMMC.
                R 1 Reply Last reply Reply Quote 1
                  #1 Done
                  #2 Done
                  #3 Done
                  #4 Failed.
                  It cannot reboot successfully from USB, even I tried many times with the instruction” quickly press the power button many times, no less than 8 times”
                  #5 To be continued
                  Could you please hep to fix step 4 ?
                    @reallaowu
                    Had you installed it successfully? You’re highly appreciated if you could share your detailed steps.
                    R 1 Reply Last reply Reply Quote 0
                      @Rock
                      Due to compatibility issues with USB3.0 devices, you can try booting with USB2.0 devices.
                        reallaowu @Rock last edited by
                        @Rock you should download Etcher, then use the software to program the image
                          I bought a new USB2.0 stick, my laptop entered into 24.04 after restarting, however I couldn’t find my previous downloaded img file in the harddrive , even the harddrive is mounted .
                          What should I do next step? Where can I find the Img file and copy it to the usb?
                            @reallaowu
                            Yes, thank you, I did that.
                              @Rock
                              You can download the image again to the 24.04 system directory. If you downloaded to 22.04 before, you must first mount mmcblk0p2 to the system and then find the image you downloaded earlier in the corresponding folder.
