    lxc-checkconfig fail in latest kernel 6.1
      berkaroad last edited by
      > lxc-checkconfig
      LXC version 5.0.3
      --- Namespaces ---
      Namespaces: enabled
      Utsname namespace: enabled
      Ipc namespace: enabled
      Pid namespace: enabled
      User namespace: enabled
      Network namespace: enabled
      --- Control groups ---
      Cgroups: enabled
      Cgroup namespace: enabled
      Cgroup v1 mount points:
      Cgroup v2 mount points:
       - /sys/fs/cgroup
      Cgroup device: enabled
      Cgroup sched: enabled
      Cgroup cpu account: enabled
      Cgroup memory controller: enabled
      Cgroup cpuset: enabled
      --- Misc ---
      Veth pair device: enabled, not loaded
      Macvlan: enabled, not loaded
      Vlan: enabled, not loaded
      Bridges: enabled, not loaded
      Advanced netfilter: enabled, not loaded
      CONFIG_IP_NF_TARGET_MASQUERADE: enabled, not loaded
      CONFIG_IP6_NF_TARGET_MASQUERADE: missing
      CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loaded
      CONFIG_NETFILTER_XT_MATCH_COMMENT: enabled, not loaded
      FUSE (for use with lxcfs): enabled, not loaded
      --- Checkpoint/Restore ---
      checkpoint restore: missing
      CONFIG_FHANDLE: enabled
      CONFIG_EVENTFD: enabled
      CONFIG_EPOLL: enabled
      CONFIG_UNIX_DIAG: missing
      CONFIG_INET_DIAG: missing
      CONFIG_PACKET_DIAG: missing
      CONFIG_NETLINK_DIAG: missing
      File capabilities: enabled
      Note : Before booting a new kernel, you can check its configuration
      usage : CONFIG=/path/to/config /usr/bin/lxc-checkconfig
        george @berkaroad last edited by
        @berkaroad said in lxc-checkconfig fail in latest kernel 6.1:
        lxc-checkconfig
        LXC related configurations can be self enabled in the kernel.
          berkaroad @george last edited by
          @George ok. just suggest for default. I compile and well done.
