    Purchase Components only
      Eel last edited by
      Hello,
      is there a seller that sells all the components apart from each other? I would like to tinker with bigger battery and a 4k display when display testing is finished.
        george @Eel last edited by
        @Eel
        The current structure cannot install a 4K resolution monitor. As for the battery, a new 53WH version will be released for users to replace.
          Eel @george last edited by
          @george Thanks for your reply, as far as i remember there was a post somewhere about 4k panels being tested, so is there a new structure coming soon?
            @Eel
            The 4K panel can only light up normally on the motherboard, but in fact, 4K will bring an increase in power consumption, which feels a bit unprofitable. I have been working hard on power consumption recently, hoping to make significant progress.
            E 2 Replies Last reply Reply Quote 1
              @george i understand, 4k will stress the chip alot more so it is not worth the tradeoff in my opinion, a bigger battery is more important i suppose.
                @george Do you know if the laptop case is custom made and if i can buy the case only?
                  @Eel
                  There is currently no separate purchase link for the casing of this machine. If any part of your machine is damaged, you can send it out and I can coordinate with the factory to see if it can be shipped separately.
