    CoolPi 4B无法进入Android系统
      traceback last edited by
      CoolPi 4B 从SD卡启动,在系统启动阶段会出现随机卡死/无限重启的情况,操作步骤如下:
      下载20230517-coolpi-4b-android12镜像,使用balena etcher烧录到SD卡中,启动系统,从串口看输出,不能进入系统,具体表现是在加载系统时无限重启(之前遇到过,今天没有遇到)或卡死(如图)屏幕截图 2024-09-25 124341.png
      尝试过的解决方案:
      1.更换2023042819-coolpi-4b-android镜像,同样卡死
      2.更换SD卡,仍然卡死
      3.把SD卡插上读卡器,从靠下的USB3.0进行引导,仍然卡死
      4.更换功率更大的充电器(之前用的是官方自带的)
      请问一下有大佬遇见过这种情况吗?不胜感激!
      T G 2 Replies Last reply Reply Quote 0
        traceback @traceback last edited by
        重启时的截图如下:屏幕截图 2024-09-25 130245.png
          george @traceback last edited by
          @traceback
          从log信息看固件的分区有问题导致,先把SD卡格式化一下,然后重新制作启动盘。
            traceback @george last edited by
            @george 你好,问题还是这样,有的时候卡死,有的时候无限重启,我买了新的读卡器和闪迪的SD卡,并且对SD卡进行了格式化,log如下:
            Device 0: unknown device
            switch to partitions #0, OK
            mmc1 is current device
            Scanning mmc 1:1...
            Found /extlinux/extlinux.conf
            434 bytes read in 7 ms (60.5 KiB/s)
            1:      Android coolpi
            Retrieving file: /initrd.img
            reading /initrd.img
            13538757 bytes read in 1089 ms (11.9 MiB/s)
            Retrieving file: /Image
            reading /Image
            38920200 bytes read in 3122 ms (11.9 MiB/s)
            append: androidboot.mode=normal androidboot.serialno=9572efc46eee3f67 console=ttyS0,115200 firmware_class.path=/vendor/etc/firmware init=/init rootwait ro loop.max_part=7 androidboot.wificountrycode=CN androidboot.hardware=rk30board androidboot.boot_devices=fe2e0000.mmc androidboot.selinux=permissive irqchip.gicv3_pseudo_nmi=0 rtleth=ethaddr:22:6e:92:0d:db:66
            Retrieving file: /rk3588s-cp4.dtb
            reading /rk3588s-cp4.dtb
            225093 bytes read in 24 ms (8.9 MiB/s)
            ## Flattened Device Tree blob at 0x0a100000
              'reserved-memory' ramoops@110000: addr=110000 size=e0000
               Loading Ramdisk to eacea000, end eb9d35c5 ... OK
               Loading Device Tree to 00000000eacb0000, end 00000000eace9f44 ... OK
            Card did not respond to voltage select!
            mmc_init: -95, time 17
            mmc_init: -95, time 16
            ** Bad device mmc 0 **
            ** Unable to read file logo_kernel.bmp **
            Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000)
            Adding bank: 0x2f0000000 - 0x300000000 (size: 0x10000000)
            [   18.914489][    T7] combophy_avdd0v85: supplied by vdd_0v85_s0
            [   18.914743][  T165] mali fb000000.gpu: Kernel DDK version g13p0-01eac0
            [   18.921218][    T7] combophy_avdd1v8: supplied by avcc_1v8_s0
            [   18.927539][  T165] mali fb000000.gpu: leakage=14
            [   18.935651][    T7] vcc_mipidphy0: supplied by vcc_3v3_s3
            [   18.937364][  T165] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
            [   18.950906][    T7] vcc3v3_lcd0_n: supplied by vcc_3v3_s0
            [   18.953473][  T165] mali fb000000.gpu: pvtm=859
            [   18.960490][    T7] vcc_3v3_sd_s0: supplied by vcc_3v3_s3
            [   18.964960][  T165] mali fb000000.gpu: pvtm-volt-sel=2
            [   18.973526][  T165] mali fb000000.gpu: avs=0
            [   18.973729][    T7] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
            [   18.980417][  T165] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 136; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
            [   18.988343][    T7] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 3
            [   19.005393][  T165] mali fb000000.gpu: GPU hardware issue table may need updating:
            [   19.005393][  T165] r0p0 status 5 is unknown; treating as r0p0 status 0
            [   19.014368][    T7] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 8
            [   19.028533][  T165] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0
            [   19.039113][    T7] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 9
            [   19.047048][  T165] mali fb000000.gpu: No priority control manager is configured
            [   19.057596][    T7] rockchip-drm display-subsystem: failed to get hdmi0_phy_pll: -2
            [   19.064985][  T165] mali fb000000.gpu: No memory group manager is configured
            [   19.072619][    T7] rockchip-drm display-subsystem: failed to get hdmi1_phy_pll: -2
            [   19.079672][  T165] mali fb000000.gpu: Protected memory allocator not available
            [   19.095418][  T165] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT
            [   19.099506][    T7] rockchip-drm display-subsystem: bound fdd90000.vop (ops vop2_component_ops)
            [   19.104838][  T165] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model'
            [   19.114748][    T7] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver
            [   19.122965][  T165] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0]
            [   19.130580][    T7] rockchip-drm display-subsystem: bound fde80000.hdmi (ops dw_hdmi_rockchip_ops)
            [   19.140734][  T165] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0]
            [   19.149573][    T7] rockchip-drm display-subsystem: bound fde20000.dsi (ops dw_mipi_dsi2_ops)
            [   19.160003][  T165] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0]
            [   19.168438][    T7] rockchip-drm display-subsystem: bound fde50000.dp (ops dw_dp_component_ops)
            [   19.177344][  T165] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = ''
            [   19.186998][    T7] rockchip-drm display-subsystem: route-dsi0: failed to get logo,offset
            [   19.196941][  T165] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model
            [   19.203631][    T7] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
            [   19.215090][  T165] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
            [   19.223542][    T7] rockchip-drm display-subsystem: can't not find any logo display
            [   19.240476][    T7] rockchip-drm display-subsystem: failed to show kernel logo
            [   19.248932][    T7] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
            [   19.253405][  T165] mali fb000000.gpu: Probed as mali0
            [   19.263466][    T7] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
            [   19.272254][    T7] input: adc-keys as /devices/platform/adc-keys/input/input1
            [   19.280578][    T7] debugfs: File 'Capture' in directory 'dapm' already present!
            [   19.347784][  T165] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
            [   19.348504][    T1] rkcif rkcif-mipi-lvds2: clear unready subdev num: 1
            [   19.355569][  T165] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
            [   19.362170][    T1] rockchip-csi2-dphy0: No link between dphy and sensor
            [   19.369473][  T165] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
            [   19.376298][    T1] rockchip-csi2-dphy0: No link between dphy and sensor
            [   19.382434][  T165] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 80,32 bit host data width,256 deep fifo
            [   19.389098][    T1] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
            [   19.389102][    T1] rkcif-mipi-lvds2: Async subdev notifier completed
            [   19.412646][  T165] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
            [   19.415579][    T1] rockchip-csi2-dphy0: No link between dphy and sensor
            [   19.415585][    T1] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
            [   19.441973][    T1] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
            [   19.450545][  T181] rockchip-csi2-dphy0: No link between dphy and sensor
            [   19.450978][    T1] RKNPU fdab0000.npu: Adding to iommu group 0
            [   19.457269][  T181] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
            [   19.463222][    T1] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
            [   19.472984][  T181] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
            [   19.492334][    T1] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
            [   19.501553][    T1] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
            [   19.510759][    T1] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
            [   19.520096][    T1] [drm] Initialized rknpu 0.8.2 20220829 for fdab0000.npu on minor 1
            [   19.522504][  T172] mmc_host mmc2: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
            [   19.531219][    T1] RKNPU fdab0000.npu: leakage=7
            [   19.543419][    T1] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
            [   19.559146][    T1] RKNPU fdab0000.npu: pvtm=871
            [   19.560277][  T172] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 135
            [   19.570375][    T1] RKNPU fdab0000.npu: pvtm-volt-sel=3
            [   19.571173][  T172] mmc2: new ultra high speed SDR104 SDXC card at address aaaa
            [   19.576605][    T1] RKNPU fdab0000.npu: avs=0
            [   19.584318][  T172] mmcblk2: mmc2:aaaa SR64G 59.5 GiB
            [   19.588080][    T1] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
            [   19.599272][  T172]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
            [   19.631946][    T1] RKNPU fdab0000.npu: failed to find power_model node
            [   19.638561][    T1] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
            [   19.645865][    T1] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
            [   19.653876][    T1] cfg80211: Loading compiled-in X.509 certificates for regulatory database
            [   19.663497][    T1] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
            [   19.670755][  T138] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
            [   19.680057][  T138] cfg80211: failed to load regulatory.db
            [   19.686056][    T1] rockchip-pm rockchip-suspend: not set pwm-regulator-config
            [   19.693591][    T1] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 409; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '18:43:18', on 'May 17 2023'.
            [   19.714508][    T1] Mali:
            [   19.714509][    T1] Mali device driver loaded
            [   19.721558][    T1] rkisp rkisp0-vir0: clear unready subdev num: 1
            [   19.727842][    T1] rkisp0-vir0: Async subdev notifier completed
            [   19.733838][    T1] ALSA device list:
            [   19.737493][    T1]   #0: rockchip,hdmi0
            [   19.741405][    T1]   #1: rockchip,es8316-codec
            [   19.745970][    T1] dw-apb-uart feb50000.serial: forbid DMA for kernel console
            [   19.753392][    T1] Freeing unused kernel memory: 1344K
            [   19.764203][    T1] Run /init as init process
            wait for device.
            0x5344
            [   19.919481][  T250] Set signal voltage to initial state
            [   19.925076][  T250] rk860-regulator 2-0042: rk860..... reset
            [   19.931741][  T250] rk860-regulator 2-0042: force rk860x_reset ok!
            [   19.937936][  T250] rk860-regulator 0-0043: rk860..... reset
            [   19.944591][  T250] rk860-regulator 0-0043: force rk860x_reset ok!
            [   19.950786][  T250] rk860-regulator 0-0042: rk860..... reset
            [   19.957441][  T250] rk860-regulator 0-0042: force rk860x_reset ok!
            [   19.968899][  T250] mpp_av1dec av1d-master: shutdown device
            [   19.974480][  T250] mpp_av1dec av1d-master: shutdown success
            [   19.980282][  T250] [WLAN_RFKILL]: Enter rfkill_wlan_shutdown
            [   19.986026][  T250] [WLAN_RFKILL]: rockchip_wifi_power: 0
            [   19.991424][  T250] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
            [   19.998013][  T250] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
            [   20.004108][  T250] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 0
            [   20.010059][  T250] rkisp_hw fdcb0000.rkisp: rkisp_hw_shutdown
            [   20.015895][  T250] mpp_rkvdec2 fdc48100.rkvdec-core: shutdown device
            [   20.022323][  T250] mpp_rkvdec2 fdc48100.rkvdec-core: shutdown success
            [   20.028845][  T250] mpp_rkvdec2 fdc38100.rkvdec-core: shutdown device
            [   20.035273][  T250] mpp_rkvdec2 fdc38100.rkvdec-core: shutdown success
            [   20.041795][  T250] mpp_rkvenc2 fdbe0000.rkvenc-core: shutdown device
            [   20.048222][  T250] mpp_rkvenc2 fdbe0000.rkvenc-core: shutdown success
            [   20.054747][  T250] mpp_rkvenc2 fdbd0000.rkvenc-core: shutdown device
            [   20.061176][  T250] mpp_rkvenc2 fdbd0000.rkvenc-core: shutdown success
            [   20.067699][  T250] mpp-iep2 fdbb0000.iep: shutdown device
            [   20.073173][  T250] mpp-iep2 fdbb0000.iep: shutdown success
            [   20.078740][  T250] mpp_vepu2 fdbac000.jpege-core: shutdown device
            [   20.084908][  T250] mpp_vepu2 fdbac000.jpege-core: shutdown success
            [   20.091169][  T250] mpp_vepu2 fdba8000.jpege-core: shutdown device
            [   20.097335][  T250] mpp_vepu2 fdba8000.jpege-core: shutdown success
            [   20.103596][  T250] mpp_vepu2 fdba4000.jpege-core: shutdown device
            [   20.109764][  T250] mpp_vepu2 fdba4000.jpege-core: shutdown success
            [   20.116024][  T250] mpp_vepu2 fdba0000.jpege-core: shutdown device
            [   20.122193][  T250] mpp_vepu2 fdba0000.jpege-core: shutdown success
            [   20.128455][  T250] mpp_jpgdec fdb90000.jpegd: shutdown device
            [   20.134276][  T250] mpp_jpgdec fdb90000.jpegd: shutdown success
            [   20.140202][  T250] mpp_vepu2 fdb50000.vepu: shutdown device
            [   20.145850][  T250] mpp_vepu2 fdb50000.vepu: shutdown success
            [   20.151584][  T250] mpp_vdpu2 fdb50400.vdpu: shutdown device
            [   20.157232][  T250] mpp_vdpu2 fdb50400.vdpu: shutdown success
            [   20.163049][  T250] xhci-hcd xhci-hcd.4.auto: remove, state 4
            [   20.168786][  T250] usb usb6: USB disconnect, device number 1
            [   20.174793][  T250] xhci-hcd xhci-hcd.4.auto: USB bus 6 deregistered
            [   20.181314][  T250] xhci-hcd xhci-hcd.4.auto: remove, state 4
            [   20.187057][  T250] usb usb5: USB disconnect, device number 1
            [   20.193103][  T250] xhci-hcd xhci-hcd.4.auto: USB bus 5 deregistered
            [   20.200265][  T250] reboot: Restarting system
              @traceback 使用2023042819-coolpi-4b-android镜像,会卡死在I/TC: Secondary CPU 7 switching to normal world boot
                emtohere @traceback last edited by
                @traceback 兄弟,问题解决了吗?我遇到了一样的问题,还不知怎么处理。
