    Ubuntu Kernel 6.1.75, no wireguard or openvpn modules
      Momo 0 last edited by Momo 0
      modprobe cant start openvpn or wireguard? Seems there are kernel-headers missing
        george @Momo 0 last edited by george
        @Momo-0
        Using the kernel at the following address, after compilation, headers. tar. gz will be generated, and then decompressed to the/usr directory.
        https://github.com/coolpi-george/coolpi-kernel
          Momo 0 @george last edited by
          @george did that, but these are the same files i already have on the machine, so there must be an issue with the repository
            Momo 0 @Momo 0 last edited by
            I rebuild the Kernel and upgraded it, seems that it doesn't support Wireguard or openvpn
              @Momo-0
              Please provide detailed error message.
                @george sudo modprobe wireguard gives me:
                "modprobe: FATAL: Module wireguard not found in directory /lib/modules/6.1.75"
                  @Momo-0
                  Add the configuration as shown in the following figure, and then compile and update the kernel.
                  diff --git a/arch/arm64/configs/rk3588_cpcm5_notebook_v20_defconfig b/arch/arm64/configs/rk3588_cpcm5_notebook_v20_defconfig
                  index e6dba9677bd9..fe61fbaa04ef 100644
                  --- a/arch/arm64/configs/rk3588_cpcm5_notebook_v20_defconfig
                  +++ b/arch/arm64/configs/rk3588_cpcm5_notebook_v20_defconfig
                  @@ -309,6 +309,8 @@ CONFIG_BLK_DEV_DM=y
                   CONFIG_DM_THIN_PROVISIONING=y
                   CONFIG_NETDEVICES=y
                   CONFIG_DUMMY=y
                  +CONFIG_WIREGUARD=m
                  +CONFIG_WIREGUARD_DEBUG=y
                   CONFIG_MACVLAN=y
                   CONFIG_IPVLAN=y
                   CONFIG_VXLAN=y
                    @george that did it, wireguard works now, thanks
