    CM5备份问题
    2182
      Twsuts 0 last edited by
      使用bash.sh脚本拷贝系统到移动硬盘,生成了.img镜像和.fs文件,如何复制到另一个系统上
        Twsuts 0 @Twsuts 0 last edited by
        @Twsuts-0 有没有人来回答我一下🤕
          george @Twsuts 0 last edited by
          @Twsuts-0
          参考如下附件backupimg.sh
            Twsuts 0 @george last edited by
            @george 我使用的就是这个脚本,新的系统已经拷贝下来了,生成了20241031-rootfs.img和backup.fs,两个文件,我把img文件下载到板子中系统工作不正常。我要如何安装到另外一个板子上
              @Twsuts-0
              你不能工作的启动信息有没有,发一下。
                @george DDR V1.10 75d050770f typ 23/02/28-20:47:10
                LPDDR4X, 2112MHz
                channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
                channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
                channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
                channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
                Manufacturer ID:0xff
                CH0 RX Vref:28.5%, TX Vref:23.8%,22.8%
                CH1 RX Vref:27.9%, TX Vref:21.8%,21.8%
                CH2 RX Vref:28.5%, TX Vref:22.8%,21.8%
                CH3 RX Vref:28.5%, TX Vref:22.8%,21.8%
                change to F1: 528MHz
                change to F2: 1068MHz
                change to F3: 1560MHz
                change to F0: 2112MHz
                out
                INFO: Preloader serial: 2
                NOTICE: BL31: v2.3():v2.3-557-g9609b9c19:derrick.huang
                NOTICE: BL31: Built : 14:29:57, Mar 8 2023
                INFO: spec: 0x1
                INFO: ext 32k is valid
                INFO: ddr: stride-en 4CH
                INFO: GICv3 without legacy support detected.
                INFO: ARM GICv3 driver initialized in EL3
                INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
                INFO: system boots from cpu-hwid-0
                INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
                INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
                INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
                INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
                INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
                INFO: BL31: Initialising Exception Handling Framework
                INFO: BL31: Initializing runtime services
                INFO: BL31: Initializing BL32
                I/TC:
                I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022骞? 09鏈? 20鏃? 鏄熸湡浜? 09:41:09 CST aarch64
                I/TC: Primary CPU switching to normal world boot
                INFO: BL31: Preparing for EL3 exit to normal world
                INFO: Entry point address = 0x200000
                INFO: SPSR = 0x3c9
                COOLPI LOADER BY YANYI(Apr 11 2023)
                DRAM: 8 GiB
                Using default environment
                0 2 1 3 6 8 7 9 edid base block is 0, get edid failed
                can't get edid block:0
                failed to get edid
                hdmi info isn't saved in main block
                mode:1920x1080 bus_format:0x100a
                hdmi@fde80000: detailed mode clock 148500 kHz, flags[5]
                H: 1920 2008 2052 2200
                V: 1080 1084 1089 1125
                bus_format: 100a
                VOP update mode to: 1920x1080p0, type: HDMI0 for VP0
                dclk:148500,if_pixclk_div;2,if_dclk_div:4
                rockchip_vop2_init: hdmi0_phy_pll may not define
                rockchip_vop2_init: hdmi1_phy_pll may not define
                assigned-clock-parents's node not define
                VP0 set crtc_clock to 148500KHz
                VOP VP0 enable Esmart0[356x124->356x124@782x478] fmt[1] addr[0xedf21000]
                CEA mode used vic=16
                mtmdsclock:148500000
                bus_width:0x16a8c8,bit_rate:1485000
                hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000
                hdptx phy pll locked!
                hdptx phy lane locked!
                dw_hdmi_setup HDMI mode
                don't use dsc mode
                dw hdmi qp use tmds mode
                boot mode: None
                Net Initialization Skipped
                Autoboot in 1 seconds
                starting USB...
                Bus usb@fc800000: USB EHCI 1.00
                Bus usb@fc840000: USB OHCI 1.0
                Bus usb@fc8c0000: USB OHCI 1.0
                Bus usb@fc400000: usb maximum-speed not found
                Register 2000140 NbrPorts 2
                Starting the controller
                USB XHCI 1.10
                scanning bus usb@fc800000 for devices... 1 USB Device(s) found
                scanning bus usb@fc840000 for devices... 1 USB Device(s) found
                scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found
                scanning bus usb@fc400000 for devices... 1 USB Device(s) found
                scanning usb for storage devices... 0 Storage Device(s) found
                Device 0: unknown device
                scanning bus for devices...
                SATA link 0 timeout.
                AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
                flags: ncq stag pm led clo only pmp fbss pio slum part ccc apst
                MMC: no card present
                mmc_init: -123, time 1
                switch to partitions #0, OK
                mmc0(part 0) is current device
                Scanning mmc 0:1...
                Found /extlinux/extlinux.conf
                289 bytes read in 4 ms (70.3 KiB/s)
                1: Linux coolpi
                Retrieving file: /initrd.img
                reading /initrd.img
                8775086 bytes read in 53 ms (157.9 MiB/s)
                Retrieving file: /Image
                reading /Image
                37032448 bytes read in 206 ms (171.4 MiB/s)
                append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseudo_nmi=0 net.ifnames=0 rtleth=ethaddr:4e:5b:8b:b6:7b:b8
                Retrieving file: /rk3588-cpcm5-rn.dtb
                reading /rk3588-cpcm5-rn.dtb
                156234 bytes read in 6 ms (24.8 MiB/s)
                Flattened Device Tree blob at 0x0a100000
                'reserved-memory' cma: addr=10000000 size=8000000
                Loading Ramdisk to eb172000, end eb9d05ae ... OK
                Loading Device Tree to 00000000eb148000, end 00000000eb171249 ... OK
                Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000)
                Adding bank: 0x2f0000000 - 0x300000000 (size: 0x10000000)
                Starting kernel ...
                I/TC: Secondary CPU 3 switching to normal world boot
                [ 12.971873] rk-pcie fe190000.pcie: IRQ msi not found
                [ 12.971889] rk-pcie fe190000.pcie: Missing config reg space
                [ 12.971979] rk-pcie fe190000.pcie: Missing config reg space
                [ 12.972008] rk-pcie fe190000.pcie: invalid resource
                [ 12.974406] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                [ 12.975415] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                [ 12.975419] rkvdec2_init:1010: No niu aclk reset resource define
                [ 12.975422] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                [ 12.975425] rkvdec2_init:1013: No niu hclk reset resource define
                [ 12.975902] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                [ 12.975905] rkvdec2_init:1010: No niu aclk reset resource define
                [ 12.975909] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                [ 12.975911] rkvdec2_init:1013: No niu hclk reset resource define
                [ 12.977398] mpp_iommu_probe:434: failed to get device node
                [ 12.977402] mpp_av1dec av1d-master: failed to attach iommu
                [ 13.096589] dw-dp fde60000.dp: failed to attach bridge: -517
                [ 13.263855] rk806 spi2.0: no sleep-setting state
                [ 13.268472] rk806 spi2.0: no reset-setting pinctrl state
                [ 13.273774] rk806 spi2.0: no dvs-setting pinctrl state
                [ 13.299922] rk_gmac-dwmac fe1b0000.ethernet: no regulator found
                [ 13.305842] rk_gmac-dwmac fe1b0000.ethernet: Can not read property: rx_delay.
                [ 13.312968] rk_gmac-dwmac fe1b0000.ethernet: set rx_delay to 0xffffffff
                [ 13.319581] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_rx
                [ 13.326271] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_tx
                [ 13.332966] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock clk_mac_speed
                [ 13.741473] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                [ 13.748766] rockchip-dmc dmc: dev_pm_opp_set_regulators: no regulator (center) found: -19
                [ 13.756938] rockchip-dmc dmc: failed to set regulators
                [ 13.777313] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                [ 13.786922] rockchip-dmc dmc: dev_pm_opp_set_regulators: no regulator (center) found: -19
                [ 13.795127] rockchip-dmc dmc: failed to set regulators
                [ 13.821344] dw-dp fde60000.dp: failed to attach bridge: -517
                [ 13.965021] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                [ 13.972237] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                [ 13.979533] debugfs: File 'HPCP L' in directory 'dapm' already present!
                [ 13.986132] debugfs: File 'HPCP R' in directory 'dapm' already present!
                [ 13.992733] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                [ 13.999419] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                [ 14.013382] rockchip-drm display-subsystem: failed to show kernel logo
                [ 14.148913] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                [ 14.157432] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                [ 14.165941] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                [ 14.178139] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                [ 14.206762] RKNPU fdab0000.npu: failed to find power_model node
                [ 14.212672] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                [ 14.219272] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                writable: recovering journal
                writable: clean, 11/490560 files, 55801/1961984 blocks
                mount: mounting /dev on /root/dev failed: No such file or directory
                mount: mounting /run on /root/run failed: No such file or directory
                run-init: can't execute '/sbin/init': No such file or directory
                Target filesystem doesn't have requested /sbin/init.
                run-init: can't execute '/etc/init': No such file or directory
                run-init: can't execute '/bin/init': No such file or directory
                run-init: can't execute '/bin/sh': No such file or directory
                run-init: can't execute '': No such file or directory
                No init found. Try passing init= bootarg.
                BusyBox v1.30.1 (Ubuntu 1:1.30.1-7ubuntu3) built-in shell (ash)
                Enter 'help' for a list of built-in commands.
                (initramfs)
                  @Twsuts-0 我复制的系统有28个G左右,我使用脚本生成的20241031-rootfs.img8个G,backup.fs25个G,我只下载了20241031-rootfs.img
                    @Twsuts-0
                    脚本具体镜像大小要修改一下,28G的数据DD的镜像尺寸至少要30G.默认脚本的8G镜像大小不合适。
                    T 2 Replies Last reply Reply Quote 0
                        @george 好的,具体如何修改,修改IMAGE_SIZE=8192吗?修改为多大
                          @Twsuts-0
                          8192是8G ,30G改为30720
                            @george 我改了以后试了,我改成多大,img就会生成多大,但实际没有这么大,下载进去也还是启动失败。
                              下面是启动信息
                              failed to get edid
                              bus_format: 100a
                              don't use dsc mode
                              boot mode: panic
                              starting USB...
                              USB XHCI 1.10
                              Scanning mmc 0:1...
                              1: Linux coolpi
                              reading /initrd.img
                              reading /Image
                              156234 bytes read in 5 ms (29.8 MiB/s)
                              Starting kernel ...
                              [ 12.971099] rk-pcie fe190000.pcie: IRQ msi not found
                              [ 12.971115] rk-pcie fe190000.pcie: Missing config reg space
                              [ 12.971204] rk-pcie fe190000.pcie: Missing config reg space
                              [ 12.971233] rk-pcie fe190000.pcie: invalid resource
                              [ 12.973628] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                              [ 12.974640] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                              [ 12.974644] rkvdec2_init:1010: No niu aclk reset resource define
                              [ 12.974647] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                              [ 12.974649] rkvdec2_init:1013: No niu hclk reset resource define
                              [ 12.975128] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
                              [ 12.975131] rkvdec2_init:1010: No niu aclk reset resource define
                              [ 12.975134] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                              [ 12.975137] rkvdec2_init:1013: No niu hclk reset resource define
                              [ 12.976633] mpp_iommu_probe:434: failed to get device node
                              [ 12.976637] mpp_av1dec av1d-master: failed to attach iommu
                              [ 13.095837] dw-dp fde60000.dp: failed to attach bridge: -517
                              [ 13.263511] rk806 spi2.0: no sleep-setting state
                              [ 13.268128] rk806 spi2.0: no reset-setting pinctrl state
                              [ 13.273431] rk806 spi2.0: no dvs-setting pinctrl state
                              [ 13.299767] rk_gmac-dwmac fe1b0000.ethernet: no regulator found
                              [ 13.305690] rk_gmac-dwmac fe1b0000.ethernet: Can not read property: rx_delay.
                              [ 13.312815] rk_gmac-dwmac fe1b0000.ethernet: set rx_delay to 0xffffffff
                              [ 13.319436] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_rx
                              [ 13.326145] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_tx
                              [ 13.332852] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock clk_mac_speed
                              [ 13.756493] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                              [ 13.763747] rockchip-dmc dmc: dev_pm_opp_set_regulators: no regulator (center) found: -19
                              [ 13.771919] rockchip-dmc dmc: failed to set regulators
                              [ 13.792529] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                              [ 13.802158] rockchip-dmc dmc: dev_pm_opp_set_regulators: no regulator (center) found: -19
                              [ 13.810369] rockchip-dmc dmc: failed to set regulators
                              [ 13.835340] dw-dp fde60000.dp: failed to attach bridge: -517
                              [ 13.975328] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                              [ 13.982558] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                              [ 13.989870] debugfs: File 'HPCP L' in directory 'dapm' already present!
                              [ 13.996479] debugfs: File 'HPCP R' in directory 'dapm' already present!
                              [ 14.003091] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                              [ 14.009785] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                              [ 14.037940] rockchip-drm display-subsystem: failed to show kernel logo
                              [ 14.172085] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
                              [ 14.180603] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                              [ 14.189113] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                              [ 14.201287] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                              [ 14.229104] RKNPU fdab0000.npu: failed to find power_model node
                              [ 14.235016] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                              [ 14.241617] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                              writable: clean, 119133/490560 files, 1957888/1961984 blocks
                              run-init: can't execute '/etc/init': Permission [ 15.023000] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
                              [ 15.034778] SMP: stopping secondary CPUs
                              [ 15.038744] CPU4: stopping
                              [ 15.038746] CPU5: stopping
                              [ 15.038749] CPU3: stopping
                              [ 15.038752] CPU: 5 PID: 0 Comm: swapper/5 Not tainted 5.10.110 #27
                              [ 15.038753] CPU2: stopping
                              [ 15.038755] Hardware name: RK3588 CoolPi CM5 EVB Board (DT)
                              [ 15.038758] Call trace:
                              [ 15.038766] dump_backtrace+0x0/0x1d0
                              [ 15.038767] CPU1: stopping
                              [ 15.038770] show_stack+0x24/0x30
                              [ 15.038775] dump_stack_lvl+0xd0/0xf8
                              [ 15.038777] CPU7: stopping
                              [ 15.038780] dump_stack+0x18/0x38
                              [ 15.038782] CPU6: stopping
                              [ 15.038785] local_cpu_stop+0x78/0x80
                              [ 15.038788] ipi_handler+0x170/0x280
                              [ 15.038794] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
                              [ 15.038797] __handle_domain_irq+0x80/0xe0
                              [ 15.038800] gic_handle_irq+0x100/0x368
                              [ 15.038802] el1_irq+0xcc/0x180
                              [ 15.038806] cpuidle_enter_state+0xe0/0x420
                              [ 15.038808] cpuidle_enter+0x44/0x5c
                              [ 15.038811] do_idle+0x238/0x2e4
                              [ 15.038814] cpu_startup_entry+0x30/0x6c
                              [ 15.038816] secondary_start_kernel+0x190/0x1ec
                              [ 15.038820] CPU: 6 PID: 0 Comm: swapper/6 Not tainted 5.10.110 #27
                              [ 15.038822] Hardware name: RK3588 CoolPi CM5 EVB Board (DT)
                              [ 15.038823] Call trace:
                              [ 15.038828] dump_backtrace+0x0/0x1d0
                              [ 15.038831] show_stack+0x24/0x30
                              [ 15.038835] dump_stack_lvl+0xd0/0xf8
                              [ 15.038837] dump_stack+0x18/0x38
                              [ 15.038840] local_cpu_stop+0x78/0x80
                              [ 15.038843] ipi_handler+0x170/0x280
                              [ 15.038847] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
                              [ 15.038849] __handle_domain_irq+0x80/0xe0
                              [ 15.038851] gic_handle_irq+0x100/0x368
                              [ 15.038854] el1_irq+0xcc/0x180
                              [ 15.038856] cpuidle_enter_state+0xe0/0x420
                              [ 15.038858] cpuidle_enter+0x44/0x5c
                              [ 15.038861] do_idle+0x238/0x2e4
                              [ 15.038864] cpu_startup_entry+0x30/0x6c
                              [ 15.038867] secondary_start_kernel+0x190/0x1ec
                              [ 15.038870] CPU: 7 PID: 0 Comm: swapper/7 Not tainted 5.10.110 #27
                              [ 15.038872] Hardware name: RK3588 CoolPi CM5 EVB Board (DT)
                              [ 15.038873] Call trace:
                              [ 15.038877] dump_backtrace+0x0/0x1d0
                              [ 15.038879] show_stack+0x24/0x30
                              [ 15.038882] dump_stack_lvl+0xd0/0xf8
                              [ 15.038884] dump_stack+0x18/0x38
                              [ 15.038887] local_cpu_stop+0x78/0x80
                              [ 15.038890] ipi_handler+0x170/0x280
                              [ 15.038893] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
                              [ 15.038896] __handle_domain_irq+0x80/0xe0
                              [ 15.038898] gic_handle_irq+0x100/0x368
                              [ 15.038900] el1_irq+0xcc/0x180
                              [ 15.038902] cpuidle_enter_state+0xe0/0x420
                              [ 15.038904] cpuidle_enter+0x44/0x5c
                              [ 15.038907] do_idle+0x238/0x2e4
                              [ 15.038909] cpu_startup_entry+0x30/0x6c
                              [ 15.038912] secondary_start_kernel+0x190/0x1ec
                              [ 15.038914] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.10.110 #27
                              [ 15.038915] Hardware name: RK3588 CoolPi CM5 EVB Board (DT)
                              [ 15.038916] Call trace:
                              [ 15.038918] dump_backtrace+0x0/0x1d0
                              [ 15.038920] show_stack+0x24/0x30
                              [ 15.038921] dump_stack_lvl+0xd0/0xf8
                              [ 15.038923] dump_stack+0x18/0x38
                              [ 15.038924] local_cpu_stop+0x78/0x80
                              [ 15.038926] ipi_handler+0x170/0x280
                              [ 15.038928] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
                              [ 15.038929] __handle_domain_irq+0x80/0xe0
                              [ 15.038930] gic_handle_irq+0x100/0x368
                              [ 15.038931] el1_irq+0xcc/0x180
                              [ 15.038932] cpuidle_enter_state+0xe0/0x420
                              [ 15.038933] cpuidle_enter+0x44/0x5c
                              [ 15.038935] do_idle+0x238/0x2e4
                              [ 15.038936] cpu_startup_entry+0x34/0x6c
                              [ 15.038938] secondary_start_kernel+0x190/0x1ec
                              [ 15.038940] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 5.10.110 #27
                              [ 15.038940] Hardware name: RK3588 CoolPi CM5 EVB Board (DT)
                              [ 15.038941] Call trace:
                              [ 15.038943] dump_backtrace+0x0/0x1d0
                              [ 15.038945] show_stack+0x24/0x30
                              [ 15.038947] dump_stack_lvl+0xd0/0xf8
                              [ 15.038947] dump_stack+0x18/0x38
                              [ 15.038949] local_cpu_stop+0x78/0x80
                              [ 15.038950] ipi_handler+0x170/0x280
                              [ 15.038952] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
                              [ 15.038954] __handle_domain_irq+0x80/0xe0
                              [ 15.038955] gic_handle_irq+0x100/0x368
                              [ 15.038956] el1_irq+0xcc/0x180
                              [ 15.038957] cpuidle_enter_state+0xe0/0x420
                              [ 15.038958] cpuidle_enter+0x44/0x5c
                              [ 15.038959] do_idle+0x238/0x2e4
                              [ 15.038961] cpu_startup_entry+0x34/0x6c
                              [ 15.038962] secondary_start_kernel+0x190/0x1ec
                              [ 15.041447] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 5.10.110 #27
                              [ 15.418349] Hardware name: RK3588 CoolPi CM5 EVB Board (DT)
                              [ 15.423907] Call trace:
                              [ 15.426346] dump_backtrace+0x0/0x1d0
                              [ 15.429999] show_stack+0x24/0x30
                              [ 15.433305] dump_stack_lvl+0xd0/0xf8
                              [ 15.436956] dump_stack+0x18/0x38
                              [ 15.440262] local_cpu_stop+0x78/0x80
                              [ 15.443914] ipi_handler+0x170/0x280
                              [ 15.447480] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
                              [ 15.452692] __handle_domain_irq+0x80/0xe0
                              [ 15.456777] gic_handle_irq+0x100/0x368
                              [ 15.460601] el1_irq+0xcc/0x180
                              [ 15.463733] cpuidle_enter_state+0xe0/0x420
                              [ 15.467905] cpuidle_enter+0x44/0x5c
                              [ 15.471470] do_idle+0x238/0x2e4
                              [ 15.474689] cpu_startup_entry+0x30/0x6c
                              [ 15.478601] secondary_start_kernel+0x190/0x1ec
                              [ 15.483120] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.10.110 #27
                              [ 15.489286] Hardware name: RK3588 CoolPi CM5 EVB Board (DT)
                              [ 15.494844] Call trace:
                              [ 15.497284] dump_backtrace+0x0/0x1d0
                              [ 15.500936] show_stack+0x24/0x30
                              [ 15.504242] dump_stack_lvl+0xd0/0xf8
                              [ 15.507893] dump_stack+0x18/0x38
                              [ 15.511199] local_cpu_stop+0x78/0x80
                              [ 15.514851] ipi_handler+0x170/0x280
                              [ 15.518417] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
                              [ 15.523630] __handle_domain_irq+0x80/0xe0
                              [ 15.527715] gic_handle_irq+0x100/0x368
                              [ 15.531539] el1_irq+0xcc/0x180
                              [ 15.534671] cpuidle_enter_state+0xe0/0x420
                              [ 15.538842] cpuidle_enter+0x44/0x5c
                              [ 15.542407] do_idle+0x238/0x2e4
                              [ 15.545626] cpu_startup_entry+0x34/0x6c
                              [ 15.549538] secondary_start_kernel+0x190/0x1ec
                              [ 15.554059] DSU CRU:
                              [ 15.556246] 00000000: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.564757] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.573268] 00000040: 00000110 00002082 00000000 00000000 00000002 000007e0 00004000 00000000
                              [ 15.581779] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.590290] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.598800] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.607311] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.615822] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.624333] 00000100: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.632843] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.641354] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.649864] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.658374] 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.666885] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.675396] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.683906] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.692417] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.700928] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.709438] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.717948] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.726459] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.734970] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.743480] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.751991] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.760502] 00000300: 0000b0c0 00001083 00000843 00000063 00000665 0000403f 00002040 0000e040
                              [ 15.769010] 00000320: 00000000 00000000 00000000 00000000
                              [ 15.774396] BIGCORE0 CRU:
                              [ 15.777015] 00000000: 00000110 00002082 00000000 00000000 00000002 000007e0 00004000 00000000
                              [ 15.785527] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.794039] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.802551] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.811062] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.819573] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.828085] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.836596] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.845107] 00000100: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.853619] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.862131] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.870644] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.879155] 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.887667] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.896179] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.904690] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.913202] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.921713] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.930224] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.938735] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.947246] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.955758] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.964269] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.972780] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.981287] BIGCORE1 CRU:
                              [ 15.983905] 00000000: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 15.992417] 00000020: 00000110 00002082 00000000 00000000 00000002 000007e0 00004000 00000000
                              [ 16.000929] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.009441] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.017953] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.026464] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.034976] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.043488] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.052000] 00000100: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.060512] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.069024] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.077536] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.086048] 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.094559] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.103071] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.111582] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.120094] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.128606] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.137117] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.145629] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.154140] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.162652] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.171164] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.179675] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.188182] PMU:
                              [ 16.190020] 00000000: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.198532] 00000020: 00000000 00000000 00000000 00000000 000000c0 000000c0 000000c0 000000c0
                              [ 16.207043] 00000040: 000000c0 000000c0 000000c0 000000c0 00000008 00000008 00000000 00000000
                              [ 16.215553] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.224064] 00000080: 000ff800 00000000 00000000 08080808 08080808 0000003c 000000ff 00000000
                              [ 16.232575] 000000a0: 00000000 00000000 00000000 00000000 000fffff 00005dc0 00005dc0 000fffff
                              [ 16.241087] 000000c0: 00005dc0 00005dc0 000fffff 00005dc0 00005dc0 000fffff 000fffff 000fffff
                              [ 16.249597] 000000e0: 000fffff 000fffff 000fffff 000fffff 000fffff 00000000 00000000 00000000
                              [ 16.258104] Kernel Offset: disabled
                              [ 16.261585] CPU features: 0x000,48040026,6a00aa18
                              [ 16.266278] Memory Limit: none
                              [ 16.269337] rockchip-thermal fec00000.tsadc: channal 0: temperature(57 C)
                              [ 16.276111] THERMAL REGS:
                              [ 16.278729] 00000000: 00000100 00000001 0000000c 0000007f 00000000 00000001 00000000 0000007f
                              [ 16.287241] 00000020: 00000000 0000007e 00000000 0000013f 0000013e 0000013f 0000013f 0000013f
                              [ 16.295752] 00000040: 0000013e 0000013f 00000000 00000000 00000000 00000000 00000000 00000000
                              [ 16.304263] 00000060: 00000000 00000000 00000000 00000153 00000000 00000000 00000000 00000000
                              [ 16.312771] 00000080: 00000000 00000000
                              denied
                              [ 16.317060] ------------[ cut here ]------------
                              [ 16.321956] WARNING: CPU: 0 PID: 0 at set_task_cpu+0x208/0x230
                              [ 16.327776] Modules linked in:
                              [ 16.330827] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.10.110 #27
                              [ 16.336993] Hardware name: RK3588 CoolPi CM5 EVB Board (DT)
                              [ 16.342555] pstate: 20400089 (nzCv daIf +PAN -UAO -TCO BTYPE=--)
                              [ 16.348550] pc : set_task_cpu+0x208/0x230
                              [ 16.352551] lr : try_to_wake_up+0x160/0x674
                              [ 16.356725] sp : ffffffc01243bcb0
                              [ 16.360031] x29: ffffffc01243bcb0 x28: 0000000000000080
                              [ 16.365335] x27: 0000000000000000 x26: 0000000000000000
                              [ 16.370638] x25: 0000000000000003 x24: ffffffc012039348
                              [ 16.375940] x23: 0000000000000001 x22: ffffffc012038918
                              [ 16.381243] x21: 0000000000000004 x20: 0000000000000001
                              [ 16.386545] x19: ffffff810082ba00 x18: 0000000000000000
                              [ 16.391848] x17: 000000990b0bb6e6 x16: 000000000000000f
                              [ 16.397150] x15: 0000000000000083 x14: 0000000000000000
                              [ 16.402451] x13: 000000000000017d x12: 071c71c71c71c71c
                              [ 16.407754] x11: 0000000000000040 x10: ffffffc012138228
                              [ 16.413056] x9 : ffffffc0100dad90 x8 : 0000000000000001
                              [ 16.418358] x7 : 0000000000000000 x6 : 00000000000000ff
                              [ 16.423661] x5 : 0000000000000000 x4 : 0000000000000000
                              [ 16.428963] x3 : 0000000000000000 x2 : ffffff810082ba00
                              [ 16.434265] x1 : 0000000000000001 x0 : 0000000000000000
                              [ 16.439567] Call trace:
                              [ 16.442008] set_task_cpu+0x208/0x230
                              [ 16.445662] try_to_wake_up+0x160/0x674
                              [ 16.449490] default_wake_function+0x2c/0x50
                              [ 16.453753] autoremove_wake_function+0x24/0x50
                              [ 16.458274] __wake_up_common+0x90/0x184
                              [ 16.462189] __wake_up_common_lock+0xb4/0x150
                              [ 16.466536] __wake_up+0x24/0x30
                              [ 16.469758] rk3x_i2c_irq+0x354/0x3d0
                              [ 16.473413] __handle_irq_event_percpu+0x88/0x264
                              [ 16.478107] handle_irq_event+0x6c/0x130
                              [ 16.482021] handle_fasteoi_irq+0xd0/0x21c
                              [ 16.486109] __handle_domain_irq+0x80/0xe0
                              [ 16.490197] gic_handle_irq+0x100/0x368
                              [ 16.494023] el1_irq+0xcc/0x180
                              [ 16.497158] cpuidle_enter_state+0xe0/0x420
                              [ 16.501332] cpuidle_enter+0x44/0x5c
                              [ 16.504899] do_idle+0x238/0x2e4
                              [ 16.508121] cpu_startup_entry+0x30/0x6c
                              [ 16.512035] rest_init+0xc8/0xd8
                              [ 16.515255] arch_call_rest_init+0x1c/0x28
                              [ 16.519343] start_kernel+0x614/0x64c
                              [ 16.522998]
                              [ 16.522998] PC: 0xffffffc0100d4f58:
                              [ 16.527951] 4d58 d503201f d503233f a9bc7bfd 910003fd a90153f3 aa0003f3 2a0103f4 a9025bf5
                              [ 16.536122] 4d78 f9400c00 b40000e0 f9400e60 f108001f 54000080 b9406a60
                              [ 16.560634] 4dd8 36000c00 90011015 911702b5 910602b5 b9400aa0 7100001f 5400080c b9404a60
                              [ 16.568804] 4df8 6b00029f 54000320 f9404260 f9402c02 b4000082 2a1403e1 aa1303e0 d63f0040
                              [ 16.576974] 4e18 f9409261 f9449660 91000421 f9448e62 b27e0000 f9009261 f9049660 b40000c2
                              [ 16.585144] 4e38 f9800271 c85f7e60 b27e0000 c8017e60 35ffffa1 f0011680 910d0000 b9401000
                              [ 16.593315] 4e58 7100001f 5400082c f9416676 2a1403f5 f9410a61 91030260 f9406ac2 f8757842
                              [ 16.601485] 4e78 9400515b f9406ac0 f8757800 f9010a60 f94066c0 f8757800 f9010660 f9408ac0
                              [ 16.609655] 4e98 f8757800 f9015e60 f94086c0 f8757800 f9015a60 d5033abf b9004a74 b9006674
                              [ 16.617825] 4eb8 a94153f3 a9425bf5 a8c47bfd d50323bf d65f03c0 d4210000 17ffffb2 b9406a60
                              [ 16.625996] 4ed8 34fff6e0 b9406a60 7100081f 54fff680 d4210000 17ffffb2 f9001bf7 97ffed57
                              [ 16.634166] 4ef8 d000d177 910022f7 b8606ae1 7100003f 1100fc20 1a81b000 13067c00 93407c00
                              bf7 2a0203f7 f9402416 f942a085 f9003fe5
                              [ 16.740378] 5098 d2800005 37400096 373803b6 37300216 37480416 aa1303e1 910103e0 d2800482
                              [ 16.748547] 50b8 9403e832 aa0003e4 b4000120 b9453a81 910103e0 b9000881 b9453e81 2901fc81
                              [ 16.756717] 50d8 2902fc97 2903fc95 94039dc4 d5384100 f9403fe2 f942a001 eb010042 d2800001
                              [ 16.764887] 50f8 54000221 a94153f3 a9425bf5 f9401bf7 a8c87bfd d50323bf d65f03c0 d2800002
                              [ 16.773057] 5118 d2800001 9403fe4d 3637fc56 17fffff0 aa1303e0 9403eaed 72001c1f 54fffd81
                              [ 16.781227] 5138 17ffffdd 944ac4ad d503233f a9b97bfd d5384102 910003fd a90153f3 aa0003f3
                              [ 16.789398]
                              [ 16.789398] LR: 0xffffffc0100dad90:
                              [ 16.794351] ab90 f8747800 9ac22400 12000000 17ffffe6 f9400341 36b7f7e1 97fd325e 17ffffbd
                              [ 16.802520] abb0 f941f741 17ffffc8 7100071f 540000e0 71000b1f 54000320 aa1a03e0 52800038
                              [ 16.810691] abd0 9402c099 17ffffbd b94002e0 d000fae1 91248021 7100001f 5400016c aa1a03e0
                              [ 16.818861] abf0 52800058 97fffe3c 17ffffb4 f9400341 36b7fc81 b9006fe2 97fd3246 b9406fe2
                              [ 16.827031] ac10 17ffffe0 f9400340 36b7fea0 97fd3241 aa0003e1 17fffff2 d4210000 d503201f
                              [ 16.835201] ac30 aa1e03e9 d503201f d503233f a9ba7bfd d5384104 910003fd
                                @Twsuts-0
                                从log信息看还是文件系统拷贝的不正确。不行就直接手动操作好了,参考脚本的命令。
                                  这个问题我也遇到了 批量还原的系统就会?
                                  要怎么解决?
                                    仔细看看脚本的代码,搞清楚备份的步骤,肯定可以操作成功的。
                                      我是用U的备份、还原镜像来做的
                                      不是手动备份的
                                      怎么手动备份,如何手动还原?
                                        @george @jugg 我快放弃了,我使用双U盘那个方法,一个拷贝系统,一个还原也不行,以前系统小的时候都是没问题的,明天删掉东西试试。
                                          @george 这是双U盘的启动信息,DDR V1.10 75d050770f typ 23/02/28-20:47:10
                                          LPDDR4X, 2112MHz
                                          channel[0] BW=164Col=90 Bk=8 CS0 Row=160肧1 Row=16 CS=2 Die BW=16 Size=2048MB
                                          channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die:BW=16 Size=2048MB
                                          CH0 RX Vref:28.5%, TX Vref:22.8%,22.8%
                                          CH1 RX Vref:27.5%, TX Vref:20.8%,21.8%
                                          CH2 RX Vref:28.5%, TX Vref:21.8%,21.8%
                                          CH3 RX Vref:29.3%, TX Vref:21.8%,21.8%
                                          change to F3:01560MHz
                                          change$to F0: 2116MHz
                                          *out
                                          INFO: spec: 0x1
                                          INFO: ddr: stride-en8>CH
                                          INFO: $ GICv3 without legacy support detected.
                                          INFO:8 hidle_st=0x21fff, xd_st=0x11fff9, repair_st=0xfff70001
                                          INFO: dfs DDR fsp_params[2].freq_mhz= 106:MHz
                                          I/TC:
                                          I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for(the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022骞? 09鏈? 20鏃? 鏄熸湡浜? 09:41:09 CST aarch64
                                          INFO:?< BL31: Preparing<for EL3 exit to normal world
                                          INFO: SPSR = 0x3c9
                                          DRAM: 8 GiB
                                          failed to get edid
                                          hdmi@fde<><00:( detailed mode2closk 14<500 kHz, flags[5]
                                          bus_format: 100a
                                          rockchip_vop2_iniv:8hdmi0_phy_plltmay not define
                                          VOP VP0 enable Esmart0[356x124->356x124@782x478] fmt[1] addr[0xedf210<0]MCEQ╩ode2usedxvic=?6
                                          don't use dsc<mo靁C醤w hdmi qt1use tmds mode
                                          boot mode: panic
                                          starting USB...
                                          Bus=].,檷?0:>00:燯SB EHCI 1.00
                                          Starting0the sontroller
                                          USB<XHCI01.10
                                          scanning bus usb@fc800000 for devices... 1 USB Devyce(s) found
                                          scanning rus usb@fc840000 for devices... 1 USB Device(s) found
                                          scanning bus usb@fc400000 for devices... cannot reset port 1!?
                                          WARN: interface 0 has 6 endpoint descriptor, different from the interface descriptor's value: 2
                                          2 USB Device(s) found
                                          scanning usb for storagexdevices..棅氀缴厺晛Device(s) found
                                          Device 0: Vendor: Rev: 2210 Prod: TSU302
                                          Type: Hard Disk
                                          Capacity: 488386.3 MB = 476.9 GB (1000215216 x 512)
                                          ... is now current device
                                          Scanning usb 0:1...
                                          Found /extlinu|/extlinu|.conf
                                          289 bytes read in 33 ms (7.8 KiB/s)
                                          1: Linux coolpi
                                          reading /initrd.img
                                          891312N逖曂乺ead in 414 ms (20.5 MiB/s)
                                          reading /Image
                                          37032448 bytes read in 1626 ms (21.7 MiB/s)
                                          append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 quiet splash plymouth.ignore-serial-consoles vt.global_cursor_default=1 irqchip.gicv3_pseun脲单?00nut.ifnames=08ztleth=ethaddr:4e:5b:8b:b6:7b:b8
                                          156294 bytes read in 38 ms (3.9 MiB/s)
                                          ##8苐yttened device Tree`闺K乹t 0x0a100000
                                          4 0Loading Ramdisk to eb150000, end eb9d00e1 ... OK
                                          Loading Devicu Tree to}00004000eb12608:, end 00000000eb14f285 ... OK
                                          Adding bank: 0x100000000 - 0x200008780 ,size: 0x100004000)MAdding bank: 0x2f8000000 - 0x300000000 (size: 0x10000000)
                                          Starting kernel ...
                                          I/TC: Secondary CPU 6 inivializing?I/TC: Sesondary CTU 4 switching to normal world boot
                                          I/TC: Secondary CPU 6 switching:to normal╳orlf0bo?5I/TC: Secondary CPU 7 initializing
                                          I/TC: Secondary cXU 24initializing
                                          [ 14.774736] rk-pcie fe190000.pcie: IRQ msi not found
                                          [ 14.774752] rk-pcie fe190000.pcie: Missing config reg space
                                          [ 14.774841] rk-pcie fe190000.pcie: Missing config reg space
                                          [ 14.774870] rk-pcie fe190000.pcie: invalid resource
                                          [ 14.777372] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
                                          [ 14.778390] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
                                          [ 14.778395] rkvdec2_init:1010: No niu aclk reset resource define
                                          [ 14.778398] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
                                          [ 14.778400] rkvdec2_init:1013: No niu hclk reset resource define
                                          [ 14.778883] mpp_rkvdec2 fdc4<100.rkvdec-core: shared_niu_a is not found!
                                          [ 14.778886] rkvdec2_init:1010: No niu aclk reset resource define
                                          [ 14.778889] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
                                          [ 14.778891] rkvdec2_init:1013: No niu hclk reset resource define
                                          [ 14.780409] mpp_iommu_probe:434: failed to get device node
                                          [ 14.780412] mpp_av1dec av1d-master: failed to attach iommu
                                          [ 14.899958] dw-dp fde60000.dp: failed to attach bridge: -517
                                          [ 15.074713] rk806 spi2.0: no sleep-setting state
                                          [ 15.079330] rk806 spi2.0: no reset-setting pinctrl state
                                          [ 15.084632] rk806 spi2.0: no dvs-setting pinctrl state
                                          [ 15.110855] rk_gmac-dwmac fe1b0000.etxernet: no regulator(found
                                          [ 15.116782] rk_gmac-dwmac fe1b0000.ethernet: Can not read property: rx_delay.
                                          [ 15.123908] rk_gmac-dwmac fe1b0000.ethernet: set rx_delay to 0xffffffff
                                          [ 15.130522] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_rx
                                          [ 15.137211] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_tx
                                          [ 15.143906] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock clk_mac_speed
                                          [ 15.547656] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
                                          [ 15.554998] rockchip-dmc dmc: dev_pm_opp_set_regulators: no regulator (center) found: -19
                                          [ 15.563170] rockchip-dmc dmc: failed to set regulators
                                          [ 15.583738] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
                                          [ 0 15.593725] rockchip-dmc dmc: dev_pm_opp_set_regulators: no regulator (center) found: -19
                                          [ 15.601939] rockchip-dmc dmc: failed to set regulators
                                          [ 15.627148] dw-dp fde60000.dp: failed to attach bridge: -517
                                          [ 15.767894] debugfs: File 'Left Hp mixer' in directory 'dapm' already present!
                                          [ 15.775110] debugfs: File 'Right Hp mixer' in directory 'dapm' already present!
                                          [ 15.782405] debugfs: File 'HPCP L' in directory 'dapm' already present!
                                          [ 15.789005] debugfs: File 'HPCP R' in directory 'dapm'0already present!
                                          [ 15.795607] debugfs: File 'HPVOL L' in directory 'dapm' already present!
                                          [ 15.802293] debugfs: File 'HPVOL R' in directory 'dapm' already present!
                                          [ 15.816712] rockchip-drm display-subsystem: failed to show kernel logo
                                          [ 15.951962] RKNPU fdab0040.npu: cqn't request region for resource [mem 0xfdab0000-0xfdabffff]
                                          [ 15.960480] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
                                          [ 15.968990] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
                                          [ 15.981201] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
                                          [ 16.009769] RKNPU fdab0000.npu: failed to find power_model(node
                                          [ 16.015680] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
                                          [ 16.022281] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
                                          wait for device.
                                          AT2S9C
                                          wait for external disk device..
                                          20+0 records in
                                          20+0 records out
                                          20971520 bytes (21 MB, 20 MiB) copied, 0.182275 s, 115 MB/s
                                          Device contains neither a valid DOS partition table, nor Sun, SGI, OSF or GPT disklabel
                                          Building a new DOS disklabel. Changes will remain in memory only,
                                          until you decide to writedthem. After that the previous content
                                          won't be recoverable.
                                          The number of cylinders for this disk is set to 1908480.
                                          There is nothing wrong with that, but this is larger than 1024,
                                          and could in certain setups cause problems wi|h:
                                          ?1) software that runs at boot time (e.g., old versions of LILO)
                                          2) booting and partitioning software from other OSs
                                          (e.g., DOS FDISK, OS/2 FDISK)
                                          Command (m for help): Partition type
                                          p primary partition (1-4)
                                          e (extended
                                          Partition number (1-4): First sector (16-122142719, default 16): Using default value 16
                                          Last sector or +size{,K,M,G,T} (16-122142719, default 122142719):
                                          Command (m for help): Selected partition 1
                                          Hex code (type"L to0list codes): Chaoged system type of partition 1 to b (Win95 FAT32)
                                          e extended
                                          Partition number (1-4): First sector (1048592-122142719, default 1448592): Using default"value 1048592
                                          Last sector or +size{,K,M,G,T} (1048592-122142719, default 122142719): Using default value 122142719
                                          Command (m for help): The partition table has been altered.
                                          Calling ioctl() to re-read`partition table
                                          mkfs.fat 4.2 (2021-01-31)
                                          fatlabel: warning - lowercase爈abels miwht not work properly on some systems
                                          total 208M
                                          -rwxr-xr-x 1 0 0 36M Dec 20 2023 Image
                                          drwxr-xr-x 2 0 0 4.0K Jun 1 2023 'System Volume Information'
                                          -rwxr-xr-x 1 0 0 176 Apr 21 2023 cmdline.txt
                                          -rwxr-xr-x 1 0 0 68 Dec020 120230 config.vxt
                                          erwxr-xr-x 2 0 0 4.0K Jun 1 2023 extlinux
                                          -rwxr-xr-x 1 0 0 8.4M Apr 21 2023 initrd.img
                                          -rwxr-xr-x 1 0 0 152M Dec 20 2023 modules.tar.gz
                                          -rwxr-xr-x 1 0 0 156K Apr 21 2023 rk3588-cpcm5-evb-v11.dtb
                                          ?-rwxr-xr-x 1 0 0 153K Dec 20 2023 rk3588-cpcm5-rn.dtb
                                          -rwxr-xr-x 1 0 0 23K May 9 2023 rk3588-cpcm5-rn.dts
                                          -rwxr-xr-x 1 0 0 13M Dec 20 2023 vmlinuz
                                          mke2fs 1.46.5 (30-Dec-2021)
                                          /dev/mmcblk0p2 contains a ext4 file system labelled 'writable'
                                          last mounted on Thu Jan 7 19:30:21 2021
                                          Discarding device blocks: 0/1513?766?? 1048576/15136766 1572864/15136766 2621440/15136766 3145728/15136766L 4194304/15136766H 4718592/15136766 5767168/15136766 6291456/15136766 7340032/15136766 7864320/15136766 8388608/15136766 9437184/15136766 9961472/1513676611010048/1513676611534336/1513676612582912/1513676614155776/15136766 done $*" ( 0
                                          Creating filesystem with 15136766 4k blocks and 3784704 inodes
                                          Filesystem UUID: 61511353-6b62-471a-963c-d36e06cb6b63
                                          Superblock backups stored on blocks:
                                          32768, 98304, 163840, 229376, 294912, 819200, 884736,$1605632, 2654208,
                                          4096000, 7962624, 11239424
                                          Allocating group tables: 0/462 done
                                          Writing inode tables: 0/462 done
                                          Creating journal (65536 blocks): done
                                          Writing superblocks and filesystem accounting information: 0/462 done
                                          e2fsck 1.46.5 (30-Dec-2021)
                                          Pass 1: Checking inodes, blocks, and sizes
                                          Pass 2: Checking0directory structure
                                          Pass 3: Checking directory connectivity
                                          Pass 4: Checking reference counts
                                          Pass 5: Checking group summary information
                                          writable: 11/3784704 files (0.0% non-contiguous), 316439/15136766 blocks
                                          resize2fs 1.46.5 (30-Dec-2021)
                                          The filesystem is already 15136766 (4k) blocks long.( Nothing to do!
                                            @george 终于可以了,把系统删减到14个G,就可以用U盘拷贝了,但是使用脚本的方法还是不可以,后面再研究了。谢谢解答👍
