    Can't Update Kernel on Armbian image (5.10) to the current one.
      rtmtree last edited by rtmtree
      I just installed Armbian image (from Onedrive) on my Notebook-v20 and got kernel 5.10.
      So I tried to upgrade the kernel to the new one by following https://cool-pi.com/topic/514/cool-pi-cm5-laptop-linux-quick-start-guide.
      I can compile kernel (from https://github.com/yanyitech/coolpi-kernel).
      but there is no dir /boot/firmware to copy to.
      and when I created /boot/firmware dir and copy /out/ to it.
      I got " No space left on device"
      ps. I cannot resize this partition with Disk Utility.
      Can the https://github.com/yanyitech/coolpi-kernel work with armbian?
      If not, how can I update kernel on the Armbian?
      Thanks in advance.
        berkaroad @rtmtree last edited by
        @rtmtree prepare linux boot udisk for rescure.
        Before copy out/ to /boot/firmware/, you should move /boot/firmware/* to your other disk, nvme or udisk. then you can copy.
        Attention: kernel 6.1 is not supported for this Armbian image, only support 5.10
        R 1 Reply Last reply Reply Quote 0
          berkaroad last edited by
          I use armbian image just for linux boot disk for rescure, because it's so small for my 8 GiB udisk.
          There something problem for dpkg, so I install ubuntu 24.0 with kernel 6.1 in laptop notebook, that's fine.
            rtmtree @berkaroad last edited by
            @berkaroad That's sad.
            Actually, Kernel 5.10 on the Armbian is quite okay.
            But I dont know why when I tried Xonotic, it's very laggy.
            I tried to install GPU support by following solution in the webboard.
            But still got like 10 FPS.
            So, I think updating the kernel could help.
