    早期版本 Ubuntu22.04 rknn toolkit lite2环境部署
      默认Ubuntu22预装python3.10,暂时与RKNN 本机开发环境不一致,需要单独安装python3.9版本。
      step1:增加源
      sudo add-apt-repository ppa:deadsnakes/ppa
      sudo apt update
      sudo apt-mark unhold libexpat1
      sudo apt install python3.9* -y
      #sudo update-alternatives --list python
      #sudo update-alternatives --install /usr/bin/python3 python3  /usr/bin/python3.9 1
      #sudo update-alternatives --config python3
      setp 2:安装pip3
      sudo apt-mark unhold libcurl4
      sudo apt install curl -y
      curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
      python3.9 get-pip.py
      export PATH=/home/ubuntu/.local/bin:$PATH
      pip3 -V
      pip3 install numpy --upgrade
      pip3 install opencv-python
      #check opencv
      python3.9 -c "import cv2; print(cv2.__version__)"
      get-pip.py
      step 3: 安装rknn toolkit lite2
      git clone https://gitee.com/yanyitech/rknpu2.git
      sudo cp -arf rknpu2/runtime/RK3588/Linux/librknn_api/aarch64/* /usr/lib/
      git clone https://gitee.com/yanyitech/rknn-toolkit2.git
      pip3 install rknn-toolkit2/rknn_toolkit_lite2/packages/rknn_toolkit_lite2-1.4.0-cp39-cp39-linux_aarch64.whl
      step 4: 验证运行环境
      cd rknn-toolkit2/rknn_toolkit_lite2/examples/inference_with_lite
      ubuntu@coolpi:~/rknn-toolkit2/rknn_toolkit_lite2/examples/inference_with_lite$ python3.9 test.py
      --> Load RKNN model
      done
      --> Init runtime environment
      I RKNN: [10:19:55.691] RKNN Runtime Information: librknnrt version: 1.4.0 (a10f100eb@2022-09-09T09:07:14)
      I RKNN: [10:19:55.691] RKNN Driver Information: version: 0.8.0
      I RKNN: [10:19:55.691] RKNN Model Information: version: 1, toolkit version: 1.4.0-c15f5e0b(compiler version: 1.4.0 (c73777b51@2022-09-05T12:06:01)), target: RKNPU v2, target platform: rk3588, framework name: PyTorch, framework layout: NCHW
      done
      --> Running model
      resnet18
      -----TOP 5-----
      [812]: 0.9996696710586548
      [404]: 0.0002492684288881719
      [657]: 1.632158637221437e-05
      [833]: 1.0159346857108176e-05
      [466 895]: 9.02384545042878e-06
      done
        大法师 last edited by
        上述环境操作不适用于新的镜像版本。
